- Jun 29, 1999
After playing with my shiny new CQC-7A for a day or two, I decided to change the chisel edge to a conventional V. Nothing wrong with the Emerson chisel grind, it cuts OK and I supposed it's easier to sharpen than a V, though the technique is basically the same. But I prefer a conventional V edge. So I clamped an ancient Buckmaster honing guide on the back of the CQC-7A so it would produce a more acute angle and went to work on a DMT ultra coarse hone clamped in a workbench vice. Starting with the flat side, I worked it back and forth with moderate pressure until the straight portion of the blade had an even bevel on each edge. That took about half an hour and several thousand strokes, stopping every so often to clean the hone. That was the easy part. The curved tip was harder. I went to my Ryobi rotary tool (Japanese Dremel), and with a round diamond rod at low speed, and the blade held against a thick piece of leather, worked the bevel back around to the tip, very gently so as not to overheat the steel. A nice burr was formed along the entire cutting edge. Then it was on to the DMT bench stones, regular (red) and fine (green), to work off the burr. Ended up with an even, polished V edge that rivals the sharpest blade in my collection, a Scandi in 1070 by Ivan Campos. Emerson CM154 really takes a fine edge; it now easily pops a standing hair. It didn't require taking much metal off, and it was fairly simple to do.
