Ive been looking and reading about them for a while, but once they started the double bevel one pulled the trigger.
Recently acquired Grayman Megapounder 7.5 and instantly wanted to modify it.
First of all, the design of the handle is not very comfortable, as been reported by others. There is some strange hump at the bottom of the handle, right in the middle (shown on the picture). The picture came from the web site, the actual knife I received did'n look nearly as good. There is also a hump at the top edge of the blade purpose of which, other than adding width and weight is not clear to me. Both had to go. Also ground a couple of sharp corners.
I have used Grayman Satu folder as a template for the handle. Satu incidentally is a very well made folder and is one of my favorites.
The fit and finish, not unexpectedly (since the knifemaker makes it clear that the knife is quite basic), are not very fancy. The blade has pits and grooves on it, which even the black coat could not cover well. The coat itself had bumps and humps on it, looking almost spray painted (probably was).
So, I decided to try my knife making. The result is on the picture. The scales are maroon canvas micarta. Could be improved (and probably will later), but for now is quite comfortable in hand.
I used Brownells Aluma-Hide for the metal under the scales. If later want to coat the blade that is what I would do (have had good experience with this stuff with firearms in the past)
The balance is now just in front of the handle, ½ to 2/4 inch back from where it was.
This of course voids the warranty, but I dont expect to need it for a knife that beefy
Before
After
Before
After
