Modifying knife handles
This is probably one of my most unusual requests for information. I have a couple of Spyderco fixed blade knives i.e. The Temperance and the Perrin. I love the design and the ergonomics of both knives really well. The only gripe I have at all is that the plastic ( FRN) handles have a bit to be desired. I am contemplating taking the Temperance handle and coating it with an epoxy type paint with some traction grit in it like you use on stairways.
I figure that will give me more traction using the knife and make the grip seem more controllable. I've also thought about putting friction tape on it but I know that stuff will eventually give out, get sticky and yucky. OK here's my question::>> What other suggestions do you all have for making these FRN fixed blade knife handles more functional? Short of just replacing the handle. BUt I don't know how long the tang is on either one of those models. There has to be viable solution to this. JD
Perhaps using a file and make some grooves in the handle might give you more traction.
You can use an electric engraving pencil to rough up the handles. You can even do patterns.
Bill
You could abrade with sandpaper or sandblast the FRN to roughen it up some. Or using a Dremel mounted mini sanding drum with a light touch might do the trick.
To expand on WM's file suggestion, you could use checkering files (as used to make decoration on rifle stocks) to create traction areas on the handles. These should be available from gunsmithing supply vendors. This would approximate the method used on the EKA W11 puukko shown below.
http://www.sworddepot.com/product_images/EKA-619692.jpg
OK guys I am going to try the sanding idea and I will keep you all posted as to how it works out. It really kind of blows my mind that they would have such a sterling, ergonomic fixed blade design and then be compromised with the handle. Please don't get me wrong I am a devout Spyder-head and love their knives and this is one of the few times I scratch my head and question why they did what they did.
I wish there were some way to just put a new handle on one of my Temperance models. Now as far as the file idea goes I would bet that if you did some knurling like they do on gunstock handles I bet that would help. I have 6 of these Temperance models ( 3 SE & 3 PE) so I got some extras to experiment with.
Now I am not closing the thread by any means. If there are more ideas to try out there then please feel free to let me know. Again my sincere thanks for your input there guys. JD Spydo
I used skateboard tape on my target pistol and it is working fine.
BTW.......
grip tape is really good stuff and meant to last. It's meant to be used on stairs and like (ie semipermanent). You don't really need to worry about it coming off as long as you've applied to a clean surface.
I think the 2 tapes I might give a try. I also took some Laquer thinner ( a very strong solvent) and it seems to make the handle a bit more grippy. I may also just look into putting a whole new replacement handle on one of my Temperance models. The knife has such good ergos it is almost worth it I feel. But I am still open to other suggestions.
Be real careful putting any kind of solvent on any synthetic material. I'd hate to hear ya woke up and there was nothin' but melted goo on the tangs of your knives! OK that may be a bit extreme, but it could make a real mess of the surface, and prolly isn't too good for the epoxy that holds the scales on either.
That grip tape will definitely work if there's a reasonably flat surface on the sides of the handles for it to stick against. I think it would be a real bear to remove if you decide you don't like it, tho.
