Mokuti care/finish
Hello all, i searched the forums for hours looking for information on how mokuti is polished/colored. I recently picked up a used john gray and the mokuti scale appears to have lost its luster. Around the pivot it still has great golds/orange/reds but below the pivot is just dull looking. Im a newbie to this material and how to care for it. Anyone willing to share their knowledge about this material?
I have ZERO experience with it. But, in reading about it, it seems the color only comes about as a surface effect when the material is heated or anodized. I get the impression, if anything is done to the finish after the fact, to shape or grind it, polish it or sand it, or whatever, the color effects will be diminished or removed, as they only exist on the surface. Couple of links below, which hint at that point.
As Carey noted, MokuTi comes from Nichols Damascus as a billet that must be worked to shape and then colored.
“[Chad] usually colors it so you can see the pattern, but that gets ground off when you work it,” Carey said, explaining that it is a surface color that does not go all the way though the material. “When you get it to final shape and finish, you have to heat color or anodize it to the colors you want.”
[/quote}
Thank you for that, i had a hard time finding much about it.
