Good catch Pete. Not to worry, per Rich, those are prototypes (proof of concept knives) and shared parts from the first batch, including the oversized latches. The production units will have proper size latches.Originally posted by ExamonLyf
Tony..., did Rich give you any indication about a time frame to look at them? Looking at the pictures of the smaller ones closely, makes me a little nervous about that pesky latch problem revisted??
No. And replacable hidden pins would be very hard to do. Because 1) Hidden pin finishes require that the excess pin material be ground and polished with the handle at the same time to make them "disappear". 2) You need to hide the access point (torx, hex, flat or phillips cutouts), while still allowing easy access to those points for disassembly. A cap insert may work, but if you make it so that it survives A) #1 above, and B) still has enough grip to stay on with all the anticipated flipping, I'm not sure how you could easily remove them to get to the access point. A very tough task for anyone to complete.Originally posted by ixpfah
btw, on the monarch, the pivot pins aren't replacable, are they?
