monochrome impressions
Being something of a knife snob I have looked down my nose at the new Benchmade "Red Line" of imported knives. Between their own ad copy claiming them to be a new option for the casual knife buyer and the unfortunate timing of their introduction with Cold Steel trying to sell us on 420 as an "uber steel" in order to pad the profit margins I was already convinced that another great knife company was on the decline to mediocrity. This opinion was reinforced when I first handled a Pica, which was in my opinion an inferior version of the old BM Ascent (incidently the Ascent was the first "real" knife I bought, so I may have an exagerated memory of its quality).
However, I kept hearing good things about the quality of the Monochrome, and every time I walked past the display case I couldn't help but look at it and wonder. How bad could it be? Finally, I gave in and gave the clerk two pictures of Andrew Jackson and he gave me the monochrome. I figured that even if it sucked I could either use it as a utility blade at work to save the edge on my nicer knives, or give it to one of my trainess as even the worst Benchmade would be a great improvement over the POS knockoffs they seem attracted to out of the academy. I was in for a suprise.
Upon extracting the knife from its packaging of Doom (more on that in a bit), I was first struck by the heft of the thing. I'm used to FRN Spydercos and G10 handled BMs. This little sucker is heavy. Next time I confiscate a digital scale from a dealer I'll weigh it, but for now its just heavy. Not unpleasently so, and in fact I've decided that I kind of like the weight. It fits with the visual aspect of the knife which is solid and pleasing in a tank like Tuetonic way. The first time I opened the blade I noticed a definate lack of smoothness and was suprised by the amount of effort required. Again I am used to the buttery smoothness of the TSEK that I tend to carry at work. Oddly, this smoothed out withen 5-10 openings and without any lubrication. A drop of FP10 to the pivot made it very smooth indeed, but due to the nature of the lock it still requires a definate shove with the thumb to get it past the point of initial resistance. This is not necesarrily a bad thing, as I once managed to stab myself in the thigh with a Benchmade Stryker that had managed to work itself open in my pocket without me knowing and then get caught up in the fabric as I sat down. As an aside the point on the Stryker was VERY good at penetrating both thin clothing and human tissue. Back on topic, I observed zero blade play in any direction and was impressed by the very solid lockup of the knife. I am confident that this frame lock will stay locked unitil either I unlock it, or the frame itself tears apart. Build quality is suprisingly good for this price point, definately on par with the "blue" benchmades and better than the lower end of Spyderco models.
The blade itself is right at three inches and came to me with the most impressive edge I've seen out of the box in a long time. It would easily shave hair and after a couple of days of light use cutting wrapping paper, tape, ribbon and general household stuff will still shave with only very slight drag. I have heard that NS60 is close to VG10 and thus far will believe that. I havn't chopped down trees or gutted wild game with this knife, but that isn't what its for really. The blade design and materials are more than adequate for general use. My only gripe with using the knife is that when I choke up on the handle for fine cutting there is nowhere for my trigger finger to go. The handle flairs out at the top comes to something of a point. This results in either my finger is crammed further down on the handle than I would like, or actually above the handle on the blade and very close to the cutting edge. Again, I am spoiled by knives like the TSEK and Native that have definate choils for your finger when in saber grip or doing fine work.
Pros:
Solid construction with good fit and finish
Visually pleasing
excellent sharpness from the factory and good retention
Bang for the buck
Cons:
ergonomics could be better
Why the hell is a razor sharp knife stored OPEN in a blister pack that takes team of mules and a chainsaw to get open? Either you reach in to pry the open knife out or the package self destructs and sends the thing straight at your tender feet. GRRRRrrrrrrr
Overall I am both suprised and pleased by the Monchrome and will be using this one as my work knife for awhile to see how it holds up. Certainly I will recomend it to the new officers coming out of the academy as an inexpensive but quality peice of gear that they might want to pick up. I'll also be buying a couple as gifts for the groomsmen in my pending enslavement ceremony...er...wedding. :)
Best regards
My condolences on your upcoming captivity, but thanks for the review of the Monochrome. It is a good-looking design, and I'm glad to read that it works as well, too. The steel used is the same as my Extrema Ratio folder, which can really take a beating. Next time someone jumps you, whack them with the knife -- it can definitely handle the pressure!
When these first came out, I fondled one in a store for awhile thinkiing of buying it, I passed for one reason. While the overall fit and finish was top notch and it seems like a well built knife, the smooth metal handle made me pass on it, because I can't imagine how you could hang on to it if your hands were the least bit slick from sweat or water.
Nice review. I loved the first monochrome I bought so much, that I gave it away and bought another one in plain edge.
I didn't know that BMs came in blister packs. Every red class BM I've bought came in an actual red box.
I have one which has replaced my CRKT M-16 as my edc lately. I like them both but the monochrome leaves far less a "footprint" in my pocket and mine opens like butter.
wazzup
Great review.
I've been carrying a monochrome since they came out and it is a very nice knife. Non threatening to most unless you flick it open fast. Takes a real sharp edge but the 690 seems to oxidize some and needs a touch up from time to time. I use a strop for this and it is fine. Lock is solid build is fine makes a nice money clip.
Joe
Great value for EDC.
The tapered handle that might make you worried about your grip also makes the knife very convenient to carry. With a little use of a Sharpmaker the blade easily gets sharper than the factory edge.
I liked it so much I had 30 of them laser engraved by BM and gave them to the people who helped me with my Eagle project.
Great review. I've been thinking about picking one of these up. It might make a nice little post holiday present for myself.
Where is this knife manufactured?
Never mind. Taiwan. I thought so. Benchmade was having some fixed blades manufactured for them in Taiwan in the 80's. I think an early version of the CS Military Classic was also manufactured there.
Unfortunately I don't own a Monochrome, but one of my ladyfriends bought one. The knife is sharp, strong and definately well built. Considering the price, this one is a good candidate for the "best bang for the buck" title. I didn't use it too much, but I found that N690 steel is a nice choice. It's a bit softer than my Cuda's 154CM, but still offers good edge retention. BTW this is the first serrated Benchmade I've seen, and I think BM's serration pattern is a very usable one. I don't care if it's made in Taiwan, the overall fit and finish is fine, especially at this pricepoint. I was impressed.
The Last Confederate:
Although the stainless steel handle the Monochrome is definately nearly not as slippery as - for example - the Spyderco Military. Maybe the cutouts of the handle help to create a nice grippy surface.
Just got my Monochrome in a couple of weeks ago and wanted to carry it for a while before I posted. What great timing. I feel it's a great knife for the money. My knife came hair popping sharp right out of the box and the action is smooth once you get the blade moving. The lock engages securely everytime with no blade play and the slim design rides in my pocket well. I bought the knife because I was curious about the N690 steel and so far it's held it's edge well. Here's a few things I noticed that it's taken some time to get used to (this is my first frame lock folder):
1 the blade takes some effort to open one handed even with the thumb stud since the handle is so slim, there's less material to push off of.
2 the thumb studs extend past the width of the handle and sometimes catches on my pocket. I think the oval hole that came on the AFCK would be easier but then the stud also acts to stiffen up the joint when it lies up against the handle in the open postion.
3 the bevel is slightly uneven on my knife so I'll have to even it out the first time I sharpen the knife.
Overall though the quality is better than I expected but I should have had more faith in Benchmade. I think it'll be a great addition to my EDC rotation and would make a good knife for any knife buyer on a budget.
Bought my monochrome from New Graham, they had a great price and as always the service was excellent. :D
