Few quick pics and notes
Here's the fat little handle. It feels very plasticky (seam and everything) and does get slippery when wet, in my experience. For the price I didn't expect much, and knew Moras were generally pretty plastic-handled, but finally holding one, I can say the handle on this one feels a bit like injeciton molded, sun-baked, 10-year old chewing gum. Mora has a good reputation and a long history though, I have little doubt about it's ability. It's just not the most pleasant texture I've ever held. It's fairly neutral and feels decent in many grips, but ideal in none. There's also not a whole lot to keep your hand from slipping up or down the handle if you were to do something stupid. Still, it works fine.
Here I gripped the knife normally, then opened my fingers a little so you can see where they naturally lie. I wear a medium-sized glove and can sometimes cram my hand into a small of some brands for a slack-free tactile fit. My pinky fits on the handle in some grips, not so well in others. Often it's left in kind of an inbetween spot, kicking out in midair trying to find purchase, or fighting with the lanyard hole.
Here are the little nubs inside the sheath that are the only thing holding the knife in. They fit into the (noticeably shallow) diamond shaped dimples that can be seen in the middle of the handle in the previous picture. The sheath also has a little flex to it. I haven't field tested it hard yet, but I could see where leaning up against a tree or something might flex the sheath enough for these little bumps to fall out of the handle dimples. With handle-down neck carry and no secondary retainment, it's possible the live blade could drop right down your shirt. Maybe it's not a problem, but I don't trust it. There are, however, little drain holes in the bottom of the sheath that you can thread paracord through, then draw it up through the lanyard hole in the handle to better secure the knife to sheath. It's not a quick-draw then, mind you. The snap-shut over-the-butt strap they sell with the upgraded kit for this knife would also help remedy this 'problem.'
For the price it's still pretty fun and well made. I didn't mean the above to sound negative, I just thought they were things I wish I'd known or were worth pointing out. The knife itself is neither really good nor bad, it's just basically what you'd expect.
Quick pluses: it came with a stellar edge and great cutting geometry. It's thin, but at that length it's not an issue and makes for an efficient blade. I hadn't thought much about that secondary grind before, but it results in a good strong scandi up near the handle where you want it and a pretty mean belly and pleasantly pokey tip up where it's double-ground.
Unless the size or weight is your thing, however, I agree I'd rather have- and would find more use for- a carbon steel 511, or other Mora, which is of similar quality but 1/3 - 1/2 the price. Personally, if it was the only knife I was taking and a tad more weight wasn't an issue I'd step up the price point and look at something else if that's within your means, not to say that this knife couldn't do pretty much anything you needed, if you needed.
I got mine as an after-thought to another order. I wanted to try out a Mora and it sounded like a cheap fun new little coffee table toy (yes, I'm a bachelor). I use it for light yard and kitchen work, mail, backyard whittling, etc., and I really do enjoy it in those roles. It's very light, and easy to throw in a pack as a secondary/emergency blade too, but in my opinion the length, grip, and sheath are inadequate for its use as a
sole camp/survival/backpacking knife. Just my 2 cents
