I've been interested in the Mora Garberg for some time as a light field blade because of the steel (Sandvik 14c28n), the wide contoured and full-sized handle, and the full tang blade.
FortyTwoBlades
sells these on his site (http://www.baryonyxknife.com/). But for a $15 add-on, he'll convert the Garberg or other Mora knife scandi grinds to a FFG and thin the blade stock, making it useful not just for bushcraft, but also giving improved performance at slicing and regular knife tasks. Haven't field tested yet, but from simple sharpness tests, this blade is slicey and does well at a variety of things I wanted, including food prep.
Specs:
Specs:
- Weight: Before (5.98oz). After (5.55oz).
- Spine width: Unchanged. About 0.130" right at the handle; a little ways out on the spine where your thumb rests, it's 0.120" as pictured below.
- Handle width at widest point: 0.87". The large, grippy, comfortable handle is one of the best things about this knife.
- Additional features (true on the factory knife as well): extended tang, 90 degree spine that strikes sparks from a ferro rod. Tested this: it throws amazingly robust sparks from any point on the spine, and from the extended tang. In fact I may slightly polish the first inch or so of the spine, it has an "edge" from the factory that is a little sharp.
