About the Scandi grind and secondary bevel.
The principle is that a knife only used for woodwork does not have a secondary bevel. It needs to be very sharp and it needs to hold a low sharpening angle, about 10 degrees.
If you use your knifes for other things (and wood sometimes), you shall use a secondary bevel.
The secondary bevels angle is depending on how just you are using your knife and to what.
The secondary bevel shall be between 1-3 degrees above primarily bevel. It shall be about 2-3 tens of an mm wide = when you can se this bevel with your eye, stop grinding!
When you use the knife it will be dull. When you sharpen your knife, you sharpen only the secondary bevel. This make the secondary bevel be wider and wider. When it have grow to about 6 tens of a mm the knife feels dull what ever you do with it then you must grind the primarily bevel so that the secondary bevel is back to 2-3 tens of a mm, then the edge is sharp again.
If you like to have a secondary bevel on your knife, start with 2 degrees angle above the primarily bevel. If this feels nice for you and the edge is holding about 10 times longer compare to no secondary bevel, keep it. If you need a little sharper edge, go down to 1 or 1,5 degree, or, if you like to have an edge who holds very long time, go up to 2,5 or 3 degrees secondary bevel.
You balance the angle in the secondary bevel after your way of using the knife it is a personal thing.
To sharpen Scandi grind:
Sharpen the secondary bevel before its gets dull.
If you wait until the edge is real dull, you must take away a lot of material from the blade to get it sharp again. If you sharpen it before its gets dull you only take away 1/1000 parts of a mm every time. Compare this with sharpen away up to a half mm when the edge is real dull
This is what we call maintaining sharpening. You just let the sharpener slide along the edge 3-4 times without pressure, that is all and your knife never gets dull. The maintaining sharpening is made in about 10 15 seconds.
So, also the secondary bevel is a very old Scandi traditional type of edge.
Thomas
