- Nov 3, 2000
<font face="Verdana, Arial" size="2">Originally posted by george tichbourne:
It could be done but what advantage would it be? The idea of the Moran or appleseed grind is to keep metal behind the edge to strengthen it. If you flat grind you have removed the metal already so why bother to try to put a convex cutting edge on it instead of a regular edge?
It just occured to me that we are confused about terminology here. The Moran "edge" you are talking about is correctly called the Moran grind, it does not refer to the actual sharpening of the edge itself. Sharpening on this variety of blade grind is done in the normal manner, usually a 17 degree angle.
</font>
