More fillet knife questions.
My racing buddies have been bugging me to make them fillet knives. What would an ideal fillet knife look like as far as dimensions and profile shape? Should it have a long even taper from the handle to the tip?
Can S35VN be well heat treated in a home setup? I have an Evenheat oven but the best I can do is subzero in the quench. I don't have cryo capabilities.
I'm also interested in this.
However, I think few more questions are in order:
a)Salt or Fresh water?
b)Type/size of fish? For example: Tuna vs pan fish?
Subbed to thread.
7" blade .75 to 1" wide. .065" S35VN stock. Distal taper in the last 2-3". profile taper last 3-4".Slight lift to the tip.
5" handle with a slight drop to the butt.
A good oven and dry ice slurry will do fine for HT. If you make a batch, sending them to Peter's is almost cheaper than doing it yourself. 20 for $100.
As for blade profile, I would look at some knives made by the guys who make them frequently and to good effect,like Phil Wilson and a few others, for profile ideas. You may find the shapes to be rather familiar. As for the steel choice, I would think that even a a high quality "cheap" steel like AEB-L properly heat treated by someone like Peters is probably going to be substantial better than what you friends are sued to hand certainly better that anything made by a fictitious guy named Bubba. :D 14C28N might be more desirable due to its increased corrosion resistance, but I haven't seen it for sale from the usual sources. Imnetion AAEB-L as Stacy fid for the simple reason that a "blank" of that i inch CPM S35VN is gong to cost you around $20-25 depending on whether you want it decarb free. The same "blank" of AEB-L will run your around $4. Something to consider if you have never made such a knife before.
Ok, good info. I have to finish some other projects before I get to this but I'm taking notes!
Jim is correct that AEB-L would certainly make a good fillet knife, but if used a lot it would need regular sharpening. It is a fraction the price of S35VN. It is all a matter of use and value of the finished knife vs. saving $20.
I FFG from spine to edge, leaving about an .005" edge thickness. Then I add a secondary that is convexed in on a 220 or 400 grit belt.
Stacy, is the primary advantage of CPM S35VN over say CPM 154 one of increased abrasion resistance or does it take a finer edge too?
Thanks. From the graphs that Crucible published, i looks like CPM 154 is tougher than S30V but has less abrasion resistance and that the addition of the little bit of niobium to S35VN closes up that toughness "gap" a fair bit while retaining the better abrasion resistance of S30V. .I guess that I will have to give both a try and see what i like better. :thumbup:
I think it is about the same in sharpness. The edge seems to last longer.
