More Foxy Folly Testing (260k of pics, dialup beware)
Light day at the Camp today. It was sunny and a bit hotter than I would've liked, but the skeeters minded their business for once and I got to chop some wood. Life is good.
I started off with reopening the fire road heading up to the Christmas tree plantation on the next lot. It was just scotch broom and saplings, nothing to write home about. No problems.
One of the benefits of working in an old growth forest is that there's always dead wood lying about, and some of it has been there long enough to get reasonably seasoned. It wasn't difficult to locate a fallen log that was nice and small to start out on.
Even the sapwood wasn't too bad. The thinner edge gives superior penetration to what I'm used to but didn't seem to sustain any damage. Just thick enough?
Since there were no problems I moved on to bigger game. This particular log was half buried in the ground so I simply pried it free and got to work.
I took frequent pauses to keep an eye on the edge. Again, there were no issues. The edge got quite hot on this one.
Since I already had the Foxy Folly embedded in that chunk of wood for photographic purposes, and the wood was nice and seasoned, I figured that I might as well split it. I found a fragment of a 2x6 that would make a suitable baton and had at it.
I hunted around for something a bit harder than wood.
That used to be a cinderblock. No problems with using the spine as an impact tool. Later, Gunnerike and myself had a bit of an argument about something sticking out of the ground. He thought it was rusty metal. I thought it was a rock. I smashed the end off with the Folly to validate my position. It was a rock. The spine did pick up some minor stippling from smashing up cinderblocks and such but it's nothing that will affect the integrity of the khuk. I wasn't able to effectively photograph it.
It wouldn't be a day in the woods without hamming it up for the camera. Unfortunately, I'd left the mask at home.
That hamon is something else, huh? Sher outdid himself on the heat treat with this one. As usual, the frog fits a USGI pistol belt perfectly. (One of my favorite things about these scabbards. Did someone send the sarkis a web belt as a pattern?)
The edge picked up a bit of toothiness again; the flats got plenty of scratches and scuffs. Stropping got the edge polished again. That nick that it'd picked up on the chair is pretty much gone. The blade remained straight despite my prying. The tip suffered slightly more toothiness than the sweet spot but stropping alone was sufficient to repair it - it just took a few more passes than the rest did. The area just ahead of the cho is noticably softer and is difficult to strop due to the radius of the curve so I've decided to leave it toothy - that's now the slicing area. ;)
The edge didn't shave at the end of the day, even after some chakma work. It doesn't have the "magic edge" that my BGRS has. It does, however, have a very good edge. After a slight loss in sharpness it doesn't seem to decrease any further. Stropping was all that was required to get it back to where it was supposed to be.
The handle has a hairline crack proceeding a quarter of the length of the handle, starting from the bolster. It's small enough that I may not have noticed it before. There appears to be a laha patch near the base of it (I'd assumed that it was a dark spot in the wood but looking more closely, I can see it for what it is) so the folks at the shop may have known that it was a potential problem from the start. The handle's on its third coat of Ballistol and appears to be soaking it up like a sponge so I'm going to wait on this one. If it lengthens or widens it'll get glued. I doubt that I could get a significant amount of adhesive in it as it is now. As it stands, I'm not even able to photograph it - far too narrow.
Also regarding the handle, it's nearly perfect for my hands. The ring fits securely between my ring and pinky fingers. This is the first occasion in recent memory where I spent some time chopping without rounding off the point first. No hot spots, no blisters...merely perfection. If you have small hands, YMMV but it's always easier to remove wood from a handle than to put it back on. Bigger is better.
IIRC Yangdu specified that the Follies weren't intended for very hard use (although she me have been referring to the longer variants) so I'd recommend caution if you're planning something along those lines. Mine is holding up very well thus far but we probably need a more statistically significant amount in circulation before we can say anything for sure.
But this one? It's a keeper, brass fittings and habaki bolster be damned.
Me likey.
That used to be a cinderblock. No problems with using the spine as an impact tool. Later, Gunnerike and myself had a bit of an argument about something sticking out of the ground. He thought it was rusty metal. I thought it was a rock. I smashed the end off with the Folly to validate my position. It was a rock. The spine did pick up some minor stippling from smashing up cinderblocks and such but it's nothing that will affect the integrity of the khuk. I wasn't able to effectively photograph it..
Holy Toledo! :eek:
The hamon line redux.:cool: It'll be wonderful if they're all like this one! :D :cool: :D
Another great review, Sat. The longer/lighter FFs were the ones not meant for heavy duty. This size model is meant to be the next versatile, all around khukuri in the HI line, so its great to see that yours held up to chopping, splitting, and smashing.
Bob
Satori, all I can say is you are a braver man than I! And thank goodness that wasn't part of an old engine block sticking up out of the ground instead of cinder block! :eek:
Of course, with that thing you would have probably just knocked a chunk off of it. :D
Thanks for a great report. I now will never worry about using mine just to chop wood, that's for sure.
Regards,
Norm
hehehe...Satori makes me wish I were still active duty myself.
Regards,
Norm
You had better test it anyway, don't never depend on no untested knife! :rolleyes: :p ;) :D
That is until you stop to think and come to your senses Uwinv.:rolleyes: ;) :D
Remember for every good detail there are still the 500 poopy ones you have to contend with.;)
LOL...yeah...luckily so far, I have snapped out of it every time before I called the Reserve recruiter. :eek: :confused: :D
You too? Every time I get to be too old to enlist, they go and raise the maximum age again! :eek: ;)
That last picture makes me proud to be an American khukuri kook
I was gonna go cut down a fallen tree limb even though it's 99 degrees, but it rained AND the groundskeepers got to it first. I do their work for them sometimes :D
The stuff I've done with the Folly is around the bottom of the expected performance envelope for HI's, as far as I'm concerned. All of my users have done far more. Since the Folly is a special case, I'm spending more time on each step and working it up more slowly. It's easy to forget just how thin that blade is when the chips are flying.
To be honest, I had my doubts about the Folly's durability after I removed it from its box. This isn't the first time that I've been dead wrong about something.
Currently, I'd call it medium duty, but I think that it has some more to show me. I have yet to see how well it holds up to a few days worth of thrashing, how the edge tolerates impacts against hard surfaces, and whether that crack in the handle is going to grow or not. (So far, not, but I'm going to drill a hole at the end of it just to be sure.)
Norm, it's interesting that you mention old engine blocks. Back in the woods there are several bullet-ridden wrecks that have been there since God knows when, or possibly before. The Folly has not progressed far enough along in its testing cycle yet to be taking on cars, but I could certainly give a few of the proven users a workout. I'll look into it.
I would like to see some Cold Steel style testing videos. But without the music, please.
What a workout- shows how tough a "medium" build can be.
Thanks for the pictorial- have a prob with the wmvs...
I vote for Satori to be named Official Khukuri Torturer, with a t-shirt & logo.
______________
(in the interrogation block, Achmed Al-Queda waits nervously. "I will never talk, never!" he shouts at the Americans.
"We've tried everything," muses the intelligence officer. "We've fed him nothing but MRE's. No cable TV. A brand of bottled water he doesn't care for. Still he won't budge. Allright. Get Satori in here."
He turns to Achmed. "You're gonna change your tune when you meet the Khukuri Torturer."
Ad Astra
Kick *ss Satori! I always feel like I test stuff out more extensively than most but you do it 10 times better! I wouldn't be afraid to own any blade you have owned!
