More Gun Maintenance Tips
Old CW4
BANNED
1. There is seldom a reason other than something known to be broken to totally disasemble a gun. It is rarely necessary to completely 'strip' a gun merely for cleaning. Toothbrushes, Q tips, pipe cleaners, etc., can be used to get into crooks and crannies when necessary. Compressed air and gun cleaning sprays can also be used although some of the sprays can damage stocks and plastics. Frankly, I usually use carburetor spray cleaner, it's cheaper but don't get it on wood, plastics, or rubber....!
2. If you must, or feel you must, disassemble a gun, obtain the exploded view diagram for it first. You can get diagrams from NRA publications, gun parts catalogs, and most of the time a quick search with Google. A very important reason to have the diagram is the pins used in most guns. There are correct ways to take them out and put them back. In a diagram, pins are shown out and on one side or the other of the frame or major component. If the pin is on the left, that means it should be driven out from the right and put back from the left. Always drive out a pin in the correct direction because some are tapered or have serrations. Driving a pin out the wrong direction, or trying to, can cause some real damage. I know, I've had to repair many for too hasty customers.
3. Again, if you must and when taking a gun apart, have a cardboard box or two handy. Put the box on your bench and work inside it to catch springs. Murphy's law is always in play with gun springs. They will fly off (if they miss hitting you in the eye) and hide in the most hard to get to places in your garage, shop, kitchen, wherever. Over my years as a gunsmith, I've spent many hours crawling around with a flashlight to find errant springs.
4. Screwdrivers. Most gun screws have straight walls in their driving slots and gunsmith screwdrivers are also straight and not tapered as are wood screws and their drivers. Do NOT use a 'wood' screwdriver on guns other than perhaps an occasional stock screw. If you work on guns, spend a few bucks and buy a set of gunsmith screwdrivers. I prefer the type with interchangeable bits and magnetized so they stay in place.
5. Stuck screws. Most handymen/women have a drill press. It can be a best friend when you have a stuck or rusted in screw. Hold the gun or gun part in a vise or clamp it to the drill press table. Then firmly chuck the correct screwdriver bit in the press, lower it down into the screw slot, lean on the press handle, and turn the chuck with your other hand. This works for me just about every time. I've broken some real bears loose this way without damaging screw, gun, or component of a gun. Of course as soon as I determine the screw is stuck or rusted, I apply some penetrating oil and let it sit for a bit. Sometimes a bit of heat application with a propane torch will also help get a screw to cooperate. Just don't overheat.
6. Trying to lighten triggers. My advice---DON'T. Gunsmiths have gauges, special jigs, and money invested in fancy stones to work on sears. Hair triggers are alright for bench rest shooters and real experts, I guess, but they're damned dangerous for everyone else. I made it a policy years ago to NOT take triggers below three pounds for customers and I'll take it down that far only if I know them and how they handle their firearms. Polishing the interior parts other than the sear at all bearing/friction points usually does as much good as a trigger job and makes for a really smooth gun.
That's it for this one but will add another true tale about a stupid gun owner. This guy went out with his young son to hunt rabbits after a fairly heavy snow storm. There were occasional snow drifts and dad, from some unknown and idiotic impulse, says "Son, watch this." He proceeds to stick the barrel of his pump 12 gauge shotgun into a snow drift and fired it. Wow! Split the barrel for about a foot down one side and jammed the bolt big time. He brought the gun to me and I refused to repair it. Told him the receiver had been stressed too much and it wouldn't be safe.
At that time, I did the repair work for a local gun store. The owner, a bit of a weirdo, sold, bought, and traded, and had done some gunsmithing.
I took some repaired guns back to him and there on his wall for sale was that same shotgun. I recognized it from some brass studs the owner had used to decorate the stock. I asked what it was doing on the wall. He told me the owner had brought it in and he'd given him twenty bucks for it on another shotgun.
He said the owner had told him what I'd said about junking the gun but, never the less, he ordered a new barrel from a gun parts catalog and fixed it himself. Told me he would easily make $150 or more on the deal. I told him I thought the gun was unsafe and he just shrugged and smiled.
Okay, I said, pay me for these guns I just brought back. He did and then I said, fix your own damned guns from now on or find another smith. I'm also going to type up a memo about this and put it in my files just in case someone gets mangled or killed firing that shotgun! I had no more dealings with the guy. I never heard of any shotgun blowups after that but who knows?
I guess 150 is worth taking the chance of someone getting hurt really bad, or even worse...
I would have done the same thing with filing the info on the shotgun. Just in case
Smooth is more important than light ! I always ask what the gun will be used for to judge the work to be done .
Loss of springs and other small parts has a big benefit - you'll end up cleaning your shop before you find it !! IIRC in gunsmithing school a spring was finally found ,on top of one of the the ceiling joists !
Have you seen the alligator hunter TV series ? The guns are in terrible condition .None are stainless steel. Sometimes they stick the rifle barrel into the water to shoot .I wonder if they get cleaned .No wonder they malfunction !
2. If you must...
3. Again, if you must...
4. Screwdrivers....
5. Stuck screws....
6. Trying to lighten triggers....
Thank you for an excellent and informative post.
Years ago, as a young police officer, I bought one of those cute little S&W Chief's Specials; the one with the 3" "bull" barrel and the squared-off grips. Only slightly less concealable than the 2" model and a tad more velocity and recoil control.
Someone on the department said that Lt. so-and-so was a real whiz with S&W actions and could really improve the weapon.
So, I let him work on the weapon. When I got it back, the action was notably smooth and light.
So light, in fact, that it wouldn't fire. I opened it up and found that the "action job" consisted of a very heavy hand with the old buffing wheel, as well as removing several turns from the mainspring....
He had actually removed much of the case-hardening from the internal parts.
In short, a pretty-much ruined pistol.
Thanks for the tips.
Do you feel this applies to all guns or is this more a general guideline? My pistol of choice is the 1911. Many people I know completely detail strip their 1911s every 5000 rounds when they replace the springs. I don't shoot that much, so I haven't had to do this yet, but I plan on following this maintenance schedule. Do you think this unnecessary?
Thanks CW4 ( I don't use the word old unless I am referring to food or ammo)
If you have additional tips to share - we are listening :thumbup:
Many years ago, I worked repairing X-ray equipment for a hospital wherein one of the doctors was a US Olympic Pistol Team member. He hardly ever cleaned his guns... and we are talking here about some very serious and very expensive guns. And he said that if you do have to break down and clean a gun, it takes at least a thousand rounds for it to "settle down" again and get consistent as he liked them. This is the man who told me that no gun, no matter how expensive -- and he had fired all of the best -- shoots straight and, while you can spend an entire day "sighting it in," the sights will never be perfect either. The trick is not to make the gun fire correctly but for you to learn to fire it correctly. I always think of this when I see guys shooting poorly blaming it on the gun.
I remember this one jerk I was selling a collectible M1 carbine to. He asked if he could strip it down and I said okay. Then he pulls out a multi-tool and asks if he can disassemble the trigger group. :eek:
No. You cannot. :mad:
:p ROTFL
I lost the magazine tube spring from a Remington 870 AOW shotgun once. I looked for it for months and finally found it when I moved some furniture for a household move. It apparently bounced off the ceiling against a wall where it fell behind some furniture without leaving a grease stain on the wall. :o
Usually, I don't want a grease stain on a wall in my house but, it would have been easier to repaint the wall then get a replacement spring.
kamagong, I built my Colt National Match 1911 for competition shooting something like 45 years ago. I have NEVER detail stripped it since then and it has had more rounds through it then I would have the patience to count. So, my answer is 'no' and there is no need to totally strip a 45 since the only spring that MIGHT need replacing is the recoil spring which can be accomplished during a normal field strip. I have never replaced the recoil spring in my National Match, I just give it a slight stretch with my hands on the rare occasions I field strip the pistol. How often do you replace the suspension springs in your car? Usually, never. I've seen three hundred year old muskets and horse pistols and their springs were still a-okay. I've seen firearms magazines that were left fully loaded for 30 plus years with the internal springs compressed and the springs were still good. Good springs really don't wear out IMO.
