S
Saia Sailo
do you have any of the original material left? If so pound it out to the same thickness as your blade, cut it into several pieces, then heat each piece to your desired temp and quench each one into something different.
Do one in warm water, one in oil and one just let it cool in air.
Then stick each one in the vice and whack it with a hammer. If it breaks, it got hard, and you have an idea on how to HT your steel.
Obviously that isn't the best way, but it'll get the job done.
The best way would be to send a piece of to get tested, so you know what the composition is, then you could develop a real HT protocol that can get the most out of the steel.... But that's expensive.
