- Jul 8, 2002
As you all might know, I work with 1095 and 15N20 damascus. I have just started an experiment for different heat treating methods to refine the grain and produce martensite. This is starting out simple, but I can see it becoming very complex before too long, there are sooooo many variables.
Right now I am doing my testing with plain C1095, not with the damascus. It has been pretty difficult to find the correct info like continuous cooling transformation curves and Isothermal transformation curves, so I have just started testing to see what happens. If any of you have or know where I can get CCT's ITT's or TTT's please let me know.
This is what I have done so far:
Three samples of 1095 that are .125 x 1.00 x 6.5
All three samples where soaked for one hour at 1525 deg F before any processes were started to try to get some grain growth.
Sample #1 went through 3 thermal cycles before being quenched. Each thermal cycle consisted of removing the sample from the oven and cooling it rapidly in air. After the air cool, it was placed back in the oven.
Sample #2 was triple quenched.
Sample #3 sat in the 1525 deg oven for 1.5 hours and was then quenched
All samples were quenched in 80 deg oil. The oil is a 50/50 mix of 10W30 and ATF. After the quench, they were allowed to cool to room temp and were then placed in the freezer for 9 hours. Interestinly I found out that steel with over 0.6% carbon will not completely tranform to martensite unless cooled to less than room temp.
The resultsto this point:
Sample #1 - 64 HRC
Sample #2 - 63 HRC
Sample #3 - 63 HRC
The next step is to temper all the samples at 350 deg for 2.5 hours and retest for hardness. The tempering will continue until a hardness of 58-59 HRC is met. Then I am going to either tensile test or try to do a bend test to find out if there is a difference in the "tuffness" of the blades.
Let me know what you all think about this, and if you want to see the further results. I don't know if 1525 is a high enough temp to grow grain or not. What I want to do in the near future is some marquencing and see how that works out. If the marquenching turns out well, I think I am going to go in that direction, since it is less stressfull on the steel during the quench.
Anyway, let me know if you all want to see more of my results as they become available.
Sample #1 - 64 HRC
Sample #2 - 63 HRC
Sample #3 - 63 HRC
