More on the perfect hatchet
I'm still trying to come up with the perfect hatchet that will still work in my handle up style sheath. This morning I forged two. The first was too small and light but I think this one will work.
By the way...this is the way a shop should look! :o
It cuts pretty well. Time will tell how perfect it is for a handle up hunting hatchet!
Peter: I sorry but if we had a Ugly Workbench contest it looks like you would win it too.:D :D
OH!! Cool hatch:) :)
Thanks George. My problem is I have too many projects going at once and I never put anything away until I can't work anymore. One of my grinders has muzzleloader parts stacked on top of it. The table saw always becomes a quickie workbench because the others are stacked.
Just to the left of the vice is my metal lathe. It is stacked up with knife parts.
I need to build an addition so I have somewhere to work!:grumpy:
Photographers often take a sheet with them to cover up extraneous stuff LOL ! There seems to be bit too much weight in the head, I would have put some of that weight to a wider blade. Tell us how it works in the field.
Looks pretty good, is that a hickory haft?.
Your right, now that's what a shop should look like. It's cleaner than mine.
The picture is a little deceptive Mete. I think it's the anvil. It's a little 25 pounder I made from a RR Rail.
The opening is square and streached pretty thin. The handle is only 5/8 in the opening. The head is really pretty light with the thickest part of the blade 1/4" I would have liked to make it wider but ran out of steel. I had to bump it pretty hard to get what I have. Maybe on the next one. I'll let you know how it handles while hunting but so far it passes the chopping test with flying colors.
No, Will, it's a piece of ash I had stuck away for handles.
Your right, now that's what a shop should look like. It's cleaner than mine How do you get anything done Will?:eek:
Peter: I made my shop bigger and now I have twice as much junk in it
That's goyya be a greater force than Murphy's Law!:D ;)
A " 25 pounder" ??? I hope you mean 2.5 lb. Having welded RR track ( it has to be preheated an post heated to prevent cracking) , I'd like to know how it was heat treated .
Nope, 25 pounds. Heat treating was done in a brick forge and then milled by a friend at Phillip Morris.
Peter , now I understand your problem - no english. Hatchet comes from the french 'hatchette' diminutive (SMALL)of hache (axe). Yours is even large for an axe !
Peter,
Just a quick question if I may, How'd you get in my shop with a camera?:o Actually, I appreciate that you cleaned up a little before snapping that pic.
That's a right handy looking hatchet you've made there.:cool:
All the best,
Mike U.
OK, now we're finally getting somewhere. But 8 oz that's a bit light for anything but light duty. A hatchet I just found is 32 oz total and my carpenters hatchet is 22 oz total.
It is light Mete, maybe too light but I'm trying to strike a balance. Consider a 10 pound muzzleloader, a 20 pound climber, 5 pounds worth of powder, ammo and cleaning stuff, food and a sleeping bag and you are pushing 50 pounds that I might have to carry 15 miles. I'm pushing 60 years old and every ounce gets important.
The hatchet wasn't intended for heavy chopping, it just replaces a camp knife, saw, large hatchet and maybe a shovel.
