There have been a few threads on this lately, so I figured I'd combine some of my questions not discussed in the others.
First, how fast do water stones cut? I was thinking of angling for a 1000/4000 grit combo stone for fathers day. The Complete Book of Sharpening says that an 800x man made stone will cut faster and leave a finer finish than a 90x Aluminum Oxide oil stone (Norton Course India?) If this is true, I'd definately like to try it. For angle control, I usually use a miter cut block screwed to a base. Can I store a water stone in water, then take it out for use, wetting it occasionally, or does it have to sit in water?
Second, does anyone sharpen knives on unsupported wet/dry sandpaper? I cut a piece of 220 grit 11x9 inch paper into 11x1 inch strips, and just put an edge on my AFCK that will cut hair, although it has to be a slicing motion. Just took 11 strokes per side, and about 3 strokes per side on my strop. I got the idea from Cliff's post about using slack sanding belts hooked on doors for reprofiling.
Thanks for all the info.
