More Talonite impression
After reading Buzzbait's many glowing comments about Talonite, I decided to give it a try. My first purchase was a CUDA Talon, intended for general use as a utility blade.
Meanwhile, Cliff Stamp has pretty much convinced me that there are far better blade steels out there for cutting and other tasks. But since no one wanted to trade a 52100 custom for the Talon, it came out of the box and started cutting...
Given that I was mostly prejudiced against Talonite as a "super blade metal", I hope this will give some unbiased impressions of the metal, and its use in the CUDA Talon.
First off, I was impressed by the overall fit and finish of this production Talonite blade. The sheath is well designed, and the Tek-Lok belt attachment system is smart and sturdy.
The blade itself has a nice shape and weight. The bevels were uneven, and the knife not very sharp (but hey, I expect this from a production knife). There were buffing scratches near the choil, but no nicks or other obvious problems. Also, the lanyard hole could be smaller (and thus stronger). I don't know how 1mm of Talonite (the thickness of the lanyard hole on the outer edge) will cope with a really hard pull.
As Buzzbait has commented, the knife would not push-cut paper, but sliced through it no problem. Also, it grooves on Cardboard like a teenager at a gaming convention. It also works wonders on cotton fabric, sponges, scrubber pads, etc. Anything soft and fibrous is no match. Against fish bones it takes a few sawing motions, but then it really <em>does</em> saw through the bone, even sounding like it!
The knife is lightweight, weighing 20% less than my large Sebenza (with the same blade width and length, and full tang on the Talon!). It feels great in my hand, even though 4" handles are usually too small for me (4 3/4" is my perfect length). I also like the flat-ground drop point format, and found it convenient for use on food, attacking boxes, etc.
Is this a "do anything" blade? I don't think so. But it <em>is</em> a "go anywhere" blade. If you forget to clean it, it won't rust. If you forget to sharpen it before going out, it will still cut. It can be field sharpened easily. I was able to get a shaving edge on it out of the box with only 2 strokes per side on my Sharpmaker. Of course, that probably just means there's a burr on the edge...
What you get with Talonite:
1. A costly blade.
2. A lightweight knife.
3. Non-magnetic.
4. Non-rusting.
5. Smooth slicing of food, very little binding.
6. Very easy to "touch up" the edge.
In short, almost the perfect picnic knife! Also great for fishing, small boating, hiking, as a box cutter, in the kitchen, etc.
But it's not a tough steel, so you should rule out chopping, prying, twisting out screws, etc. It's soft, and therefore probably quite easy to scratch or dent. I wouldn't classify this as a "hard use" blade, but rather a lighty duty utility knife requiring very little thought. The kind of knife you can toss into (or keep in) your ditty bag and never worry about.
For demanding, or performance, users, everything I've read points to other metals. I can't compare metals, since I don't own them all, but based on the weakness and softness of Talonite, there are a lot of places it can't go with confidence: For whittling, detail work, etc., a blade that takes a thinner, smoother edge is preferable. For hard, heavy-duty use, a stronger edge is preferable. For abrasive, wearing tasks, a harder edge is preferable. But if you cut mostly soft or fibrous things (string, cardboard, paper, food), then I can already recommend this blade from just a few days of going slice-happy with it. It binds far less than carbon steels, making coring bell peppers a much safer task. And it cuts cardboard so smoothly, my Stanley box cutter is now very much worried about getting lent out permanently.
To summarize: If you're money sensitive, and want something that will slice well, but also can be trusted for harder work (and more different kinds of work): you should probably look elsewhere. There's not as much "bang for the buck" here, since Talonite only seems to excel in a limited range. But Talonite does seem like a handy addition to any knife knut's repetoire, and will be seeing use as my primary "around the house" blade. For what it does well, it does it REALLY well, and if that's all you need it for, you should really give it a try. I'm sold on it for food preparation, the lightweight carry (great for hiking and bicycling), and its low-maintenance aspects. It's a knife I could use for boating, fishing, diving, and food prep, all in one day, without any worry of staining, or lack of cutting ability when I needed it most -- whether I remember to clean/sharpen it or not.
John
p.s. This post is an amalgam of both personal experience and all the other posts I've read here on Bladeforums (and elsewhere). Some of the points presented I have not verified myself, so please take this with a grain of salt. Clarification by other members, or hearing about more real world experience, would be a great help. Thanks!
JohnW: Thanks for the intelligent, well balanced comments. I think you've pretty much got it nailed. I feel very much the same way about this very exotic and expensive material. I am very pleased with my Talonite blades. They have a significant place in my knife "arsenal", but other materials are also very viable depending upon your application.:)
I’m still very impressed by talonite. You are correct that it’s an awesome blade material for small knives. My Mini-Talon and talonite EDC get usage everyday, just because they’re so darned convenient. For people who don’t venture into the backwoods much, talonite is pretty close to perfect for around-the-house chores. It handles light jobs beautifully, without the worry of rust or constant sharpening. No matter what I’m doing during the usual workweek, I always prefer to use talonite. I can get the job done and worry about any possible maintenance when I have more time to devote. Life is too short and busy to worry about knife maintenance all day long.
I wouldn’t rule out talonite for outdoor excursions either, but I’d “temper” my attitude. Talonite definitely isn’t for chopping. That’s what good tough carbon steels are for. Chopping will easily roll talonite’s edge, and hitting a knot could likely rip or chip the blade. Talonite makes for an excellent utility or small camp knife though, to be used for food prep, cutting hides, turning your blue jeans into shorts, making fuzz sticks from soft woods, cutting bandages, and any other small job around the camp. The uses of talonite for fishing are obvious. It’s kind of like a “super-440C”. Talonite’s other great outdoor feature is its ease of sharpening. Simple stropping can get you by for a long time before you have to hit it with a stone.
Oh yah…… about the sharpening…… Talonite is different than most steels I’ve sharpened. It seems closer to a soft carbon steel than a hard stainless. Hones tend to produce a very large wire edge. The wire edge is quite flexible and tough to get rid of. If all you have is a fine hone, it’s actually pretty near impossible. A leather strop is “a must” for talonite, if you want to get that hair splitting polished edge that cuts so well.
Talonite is quickly changing many of my knife preference notions. Put it this way. As good as the small Sebenza is, and you know how much I love my large Sebenza, I’d choose a talonite Camillus EDC over the small Seb in a heartbeat. The talonite EDC may not have the build and craftsmanship of a small Seb, but the cutting ability and lack of maintenance is there. It’s the ultimate small sized production folder.
The Mini-Talon has caused huge waves of envy from my other knives. The Mini gets more use than probably all of my other knives put together. The size is good enough for most urban cutting chores, and there’s nothing to worry about. It has a superior cutting edge to everything but my talonite EDC. The fact that it’s a fixed blade just makes things more secure and much easier to clean. The ergonomics of the mini-Talon are also extraordinary for such a small knife. My only caveat to the Mini-Talon is that I would prefer a convex edge. A convex edge would bring talonite from “top of the list” to “too far above the list to compare”.
In short, talonite is for me. No matter where I go, there’s always a talonite blade within arm’s reach.
Great write-up, John. You are right on the money when it comes to talonite.
Thank you for your comments. However, Mr. Simonich said in a early thread in archive that Talonite ( and cobalt alloys in general) is heavier than steels, not lighter. Differnce between your Sebenza and Talon is typical difference between comparable size folding knife and fixed blade knife, unless significantly thicker stock the fixed blade will usually be lighter.
Martin
Martin,
You are correct. Talonite is heavier than steel. I love the stuff, (and have many knives made from it), but have read threads where it's stated that Talonite and titanium make for a "featherweight" knife. No, it makes for a very corrosion resistant knife with the titanium offsetting the Talonite with it's very light weight.
I raised all my kids in Long Beach, Ca. Haven't been back there in 10 years. Welcome to the forums Martin!
a pound is a pound. although stellite might be little denser than steel, I seriously doubt if you can feel the difference in a small knife...............or is it Simonich is denser than Hossom.....I forget!?! :rolleyes:
Tom,
There may be truth in both statements . . . perhaps talonite/stellite knifemakers are just dense!?!;) ;) ;) :p :p :p
Okay Tom, I just can't resist... which is heavier, a pound of Talonite or a pound of steel? :)
Thank you for the kinds comments, I have lived here with my daughter now for 5 years. Where else can you look out and see the beautiful California sun setting behind oil rigs?:)
Martin
Can anyome compare the talonite blade to a Boker ceramic infinity? I have no ideas on the ceramic's limitations. Thank you, Dave Halliday
I have owned talonite, carbon-steel and ceramic blades. I have 3 Bokers- 2 paring blades and the infinity. Ceramic is sharp, but not super sharp. It will hold an edge forever, but do not cut anything harger than meat or vegetables. My wife has used the 2 paring blades interchangeably with our steel cutlery - and , as you probably realize, women are much tougher on blades than we are. The ceramics have many small knicks in them, but still cut. They are ideal for cutting up salad greens and vegetables. They never rust and are very easy to wash of. One was dropped on the floor and I now use a shortened warncliff style paring knife. It is as brittle as glass. I had a small Boker executive folder and put some chips in it by simply removing some staples from a report.
Ceramics are resharpenable, but require a different approach. First, since it is not flwexible, you will not get a burr to roll over. Use a diamond stone and simply get both edges to meet. Keep the angle 25 deg. or thicker. As far as the infinity is concerned. It is extremely lightweight, has a very ergonomic handle, but at the price, I only use it for cutting paper or cardboard that has no staples in it. It is an interesting material, but not useful in any heavy duty work.
