- Jun 4, 2010
Hello, am still on a kick with these and as a follow up to the other video where I do a lot of cosmetic work, this is strictly edge work on a D2 BK24, done fairly quickly. In this one instead of working up a lot of mud, am using as simply as possible.
For anyone interested, these are the stones I show, available from Global Tooling. As I mention in the video, the grit rating doesn't correspond very well to the actual abrasive size, am not sure what scale is being used.
COARSE:
8" x 2" x 3/4" - 240 grit / BLUE-GREY
Part # JS-0500 - 39C 240-J,K,L,NV - Norton Stone [Specify Hardness wanted] (NV is the hardest and what I use)
MEDIUM:
230mm x 60mm x 15mm - 500 grit / DARK BROWN
Part # JS-2121 - SC5AC 500 Euro-Stone - Resin Bond
FINE:
228mm x 60mm x 17mm - 1200 - 600 grit / DARK BROWN
Part # JS-0701 - NCD 1200/600 Diamond Stone - For CARBIDE ONLY (Presumably only for carbide because it is intended to be used at 3600-6000 RPM, being diamond - no good for HSS blades)
[video=youtube;R39wv301PLw]https://www.youtube.com/watch?v=R39wv301PLw[/video]
COARSE:
MEDIUM:
FINE:
