Mosaic pin help
Hi folks,
I'm nearing the place where I want to install some jigged bone scales on my knife and need some advice on whether or not I need to pien the mosaic (1/8") pins after running them through the holes in the tang. Should I also grind some little divots it the pins as well to add a little extra holding power?
Many thanks,
Dana Hackney
Monument, CO
You can't really pein mosaics. All that is really needed is a little bit of a roughed up surface, a quick hand sand with some 60 grit paper would be fine and then put em in and epoxy away.
Good Luck,
Sean
I was wondering if it was not a good idea peining mosaic pins.
Thank you for the help.
Best regards,
Dana
I beg to differ.
I have peined mosaic pins before (even recently), and get great results. It kinda opens up like a flower. Different look.
Experiment first with just a little piece and see what the results are.
