Mossberg 930 Cleaning?
I took the plunge and bought my first gun. A Mossberg 930. Being a semi automatic shotgun, I am more than sure it will need to be cleaned more regularly than a pump shotgun. How should I go about doing this? Any recommended kits and stuff? Thanks.
P.S. - Pictures will come later.
Any good shotgun cleaning kit (Hoppes, Outter's) will work. Don't use the oil that comes in these kits. Do yourself and your shotgun a favor and get some BreakFree CLP (Cleaner, Lubricant, Preservative) to oil it. Oil your shotgun before you fire it, and clean and oil it after you are done shooting. However, don't oil the components of the gas system unless the instruction manual calls for it.
Oil tends to burn, carborize and foul gas operated guns when fired.
TR Graham
The Glocksmith
TR Graham is right, CLP is excellent and so is Corrosion X, both available at most auto parts stores, etc. As a gunsmith, I see many guns of all types come in for repairs solely because they've been cleaned and lubed too much! Some gun owners feel compelled to detail strip, scrub, and drench their firearms in oil everytime they fire just a few cartridges or shells. Don't do it! No reason for it. I always ask these customers, "Gee, do you take your car engine and transmission out for cleaning everytime you drive it?" After a day's hunting, lubricate scantily where metal contacts metal, wipe down with a soft dry rag, and that's it. Think about scrubbing the bore and so on only after a couple of hundred rounds and then don't overdo it. The only places in a shotgun bore that really get dirty are the forcing cone area just ahead of the chamber and at the choke if you have one. And if/when you remove a choke for cleaning always lube the threads before screwing it back on.
TR is also right on about not getting cleaner or lube into the gas system because it will 'carbon up' when hot gasses come in through the bore to gas cylinder port, check your manual. When I clean a gas operated shotgun, I always have it on the bench with the trigger guard up when I scrub the bore so no or minimal bore cleaner or lube gets into the gas cylinder. Your 930 is a fine gun, enjoy it,don't overclean it, and you'll be able to pass it on to your kids.
No manual, but I can download it. Thanks for the advice. I plan on cleaning every 150 shells or so. Is that alright?
Picture as promised!
