Most common size torx screws (for scales). Need help with an order.
Svs
Hey all,
I'm going to be puting in an order with usa knife maker and wanted to add some torx screws. Thing is I'm not sure why size I should get. What's the most common screw size (used on scales)?
I had typed in T6 in the search bar and got a few result back of: 2-56 flat head 1/4"
I have a few knives with stripped or worn screws on the scales so I want to just keep some extras around.
Thank you in advance for any input!
I think it largely depends on the knife, you might get more responses if you post what sort of knives you need screws for.
I can say that I recently needed some screws for a Spyderco PM2. They are 2-56. I found screws that took a T8 Torx. I got the .25 length which is longer than factory screws but that is what I wanted. I was fitting some aftermarket scales and clip and need a little more length. I used a Dremel and a file to bring them down to the right size.
The Spyderco and Benchmade screws I have seen are Torx, I would stick to that over flat head screws.
Thanks for chiming in zephy5! I think that's the size ill get. Seems to also be the most common on the sight as well. I have a couple of P2's so I can have spares for it as well.
