most expensive micarta ever
JTknives
Blade Heat Treating www.jarodtodd.com
for a very long time I have been wanting to make a set of micarta scales out of stacked one dollar bills. what would be a good epoxy to use to get a good clear finnish.
not even i am smert enuf to try that one
good luck but im thinking that it will be hard to get the resin to soak in
Buy a couple of those bags of shredded money and make it out of that.
I'd like to see it.
MAX CLR off some ebay seller or, eager polymers EP 1319* (I think thats the number), or you might get lucky and find some quality casting resin locally. Expect to pay 50 once or more an ounce delivered. The good news is that money is durable, you may have to be fairly aggressive squeezing the resins into it. Good luck, I figure 40+ layers to get 1/8", I'd love to see the finished product.
* would be my first choice
$150-200 for a set of scales :)
As Blue Dragon said, it could depend on what the scales are doing. If they're just flat, it's possible to stack a few real bills on top, then put some other stuff in between. If you're going for a contoured handle on the other hand...:eek:
contoured, but if the bills are stacked right everything should line up and look very cool.
Why don't you get Zimbabwe money ? You could use 10,000,000 Zim notes ,a wheel barrel full would be worth about $ 20 !!!
Jarod,
I've thought of doing this before .It wouldn't run a whole lot more than the cost of a set of high end mammoth scales, and would be less than narwhal.
This is the procedure I wrote up and filed away for a rainy day:
(parenthetical notes added to make the outline clearer to others)
Materials: $200 new bills, clear resin, cardboard.
(Use a clear cast resin, like System Three Clear Coat.)
Make a box that exactly fits the bills from wood with a top that fits in it like a piston.Make the top and bottom out of 2" thick wood, the sides from 1".Drill (lots of )1/4" holes in the box sides (until it looks like swiss cheese, but leave the top and bottom solid).
Put three pieces of poster board in the bottom.
Coat each bill with resin and set in the box.
Place three more pieces of poster board at the $100 point ( no resin).
Place next $100
Add three cardboard on top (when all the bills are in the box).
Put on the top piston.
Put assembly in lg. zip lok bag (to catch all the resin drips).
Place in a clamp/press and tighten to expel the extra resin (it will leak out the holes).
Let cure (for a couple of days).
(Put the box on the) Band saw (and cut the)sides away, (then) the top and bottom.
Grind down until the poster board is just barely left on the top and bottom (and) split the scales (with a sharp knife )in the middle. Grind insides flat (and you have a set of $200 scales).
This has me thinking of this project again. Maybe I'll make up some damascus with $$$$$$$$ all through it? That would be cool. I wonder if Donald Trump wants a fancy letter opener?
The sad thing is the amount of extra that will be cut/ground away . Maybe with careful trimming some of it could be saved (like the $1 corners) and used as an inlay on another knife or the presentation box for this knife)
Just thought of a better idea while typing.Carefully cut the surplus away fron the tang after applying the scales. Use those fitted cuts as liner pieces for the presentation box ,so the knife fits back in-between them,to show what they came out of. Now that would make the whole package look impressive.
I like the idea of using foreign currency. I have a friend who might be able to get a couple of bundles of new Iraqi of Afghan bills. That would make the learning curve a lot cheaper.
I could send an email to a Nigerian bank and say.
" Helo, I am wealthy amercan who has $100,000,000 that wish to share good fortune to you. Please send 1" of new Nigerian bills to me and I wil send payment by creidt card. Thank you much."
Stacy
pretty neat idea. thats something to keep in mind. i agree with ya contour the handles (but go to the extreme) to reveal as much cross section as possible. this is just my opinion good luck to you.
Soooo...would the left side of the blade have the "heads" side of the bill and right side be "tails"? :)
