Ditto on the Good Quality Respirator.MOP and Abalone are both toxic.
If you are going to cut your own you really need lapidary equipment with water spray to do it right.If you are still determined to do it yourself,with knifemaking equipment,here is a rough procedure.Remember,everything around where you work will be coated in the dust,so work outside,and clean up well.Saw it on your metal cutting band saw at slow speed, use a good hacksaw, or jewelers saw.Grind it with new belts at slow speed.Shape and finish with files,fine stone wheels (dremmel) ,diamond burrs and wheels,and wet or dry sandpaper (use it wet).Polish with matchless white or white rouge.If using a buffer,go easy,it will burn quickly.The 3M finishing papers (those multi-colored sheets)from 400 to 8000 work excellent for hand finishing.
