- Jul 28, 2003
I'm getting the 2x72 wwith a 10" contact wheel. I am thinking a 1.5 hp motor should do, I know I need a farm duty as opposed to a compressor duty motor, What else should I look for?
A C Richards said:As you can tell from my last post I agree that if at all possible you should go ahead and get the variable speed.
rashid11 said:Compressor duty is rated for short bursts of activity: initiall fill up of tank and occasional refills, as one uses air.
Farm duty is continuous duty motor: you can run it for hours.
In the US, HF carries a VeRY decent 1HP 110/220V motor, farm duty TEFC,
for $89 - 20%. I just bought it this past weekend, in store, and replaced sh*tty 7Amp "3/4" HP motor in me Craftsman bandsaw. Night and day (15Amp vs 7A).
Chiro75 said:I love my Coote! I have a 1HP motor and I've never stalled it. Definitely get the step pulleys. I got mine from Norm and then found out that my motor had a bigger diameter shaft, so I had to order another one from Beaumont, but the speed variability is WELL worth the $$. Also, plan on putting plate glass or that ceramic stuff over your platen. It's aluminum and I had to flatten mine with about 30 minutes of draw filing after making just a couple knives on it.
Ilovetoolsteel said:Thanks for the info on the platen. I remember seeing a thread about ceramic liners somewhere around here. I will have to check it out.
"Compressor duty" means that the motor was designed for applications requiring high startup and breakdown torque. Many "compressor duty" motors are rated for continuous use. However , most have ODP (open, drip proof) frames; you are much better off using a TEFC (totally enclosed, fan cooled) frame motor on a grinder.rashid11 said:Compressor duty is rated for short bursts of activity: initiall fill up of tank and occasional refills, as one uses air.
