Motor to buffing wheel conversion
I have a 1.5hp US motors NEMA premium polyphase general purpose motor that I want to turn into a bench top buffing machine. My question is how exactly would I do this? It’s capable of 3450rpm 208-230/460 volts, 60HZ. Now just because I wrote that down does not mean I know what it all means. I would like to plug this into a 110v outlet. Is this possible without a VFD? If I do need a VFD which kind? Keep in mind I’m on a budget. Thanks!!
Edited to correct my earlier reply:
It is a three phase 220/240 volt motor.
It can run on a VFD using 115V single phase power, but won't develop more than 1HP.
It says polyphase on the sticker. Is that not what that means? It was also at one point attached to my 2x48 belt grinder and VFD. So I think it will work? How are you making this determination?
"Polyphase" generally means three phase, but technically could mean anything greater than singlephase.
But I dont remember seeing any motors specifically identified that way.
It nameplate always states "Three Phase", "3 Φ" or similar recognised symbols.
Btw,
If a VFD ran it in its prior life as grinder...
Pretty much means you need a VFD or 3 ph housepower to run it for its next configuration. With the right VFD you will be able to run it on 120VAC.
Btw,
Does this need to be a very specific vfd? I found one that is 110 and works with up to 3hp motors.
Oops, I missed the word polyphase. That is a 3 phase motor. It will require a VFD. At 1.5HP it can be run on 115V single phase, but will only develop about 1HP. It will take a 20 amp breaker to run it. The VFD won't run on a GFI breaker or socket.
I edited my earlier reply.
You need to check close on the VFD linked, it says in the description "Input:1 or 3 phase 110V. Output:3phase 110v. Frequency:0-50hz/60hz. 0-400hz" While it does say 1 ph 110V input, note the 3 ph 110V output. Your motor requires 220V for power. With "polyphase" it could be 3 ph, and since you say it's been running on a VFD that also points toward a 3 ph motor.
Keep in mind you're gonna also need a mandrel/arbor of appropriate size/configuration to hold your buff(s). Depending on your motor's frame size, there may be an adapter available for the shaft, OR, this is a really nice option: https://www.amazon.com/Shop-Fox-W16...?keywords=buffing+arbor&qid=1584206330&sr=8-7
That said, if you're on a budget, you may be better off just taking a portion of the money that this will cost to get up and running, and just buy a couple of these:
https://www.amazon.com/POWERTEC-BF6...eywords=6"+bench+buffer&qid=1584206173&sr=8-5
I highly recommend that buffer head. Use a 3/4 HP 3PH motor and VFD and you have a VS buffer for a very low price. A 3/4HP to 1HP DC motor and speed control will also work fine.
I would suggest you save the 1.5HP motor for a belt grinder or disc grinder and get a 3/4HP motor for the buffer. For our purposes 1.5HP is way more than we need for buffing.
Thanks I would have got it wired it and had no idea why it caught fire lol
https://www.amazon.com/POWERTEC-BF600-Heavy-Buffer-6-Inch/dp/B01BW8UOHC/ref=sr_1_5?keywords=6"+bench+buffer&qid=1584206173&sr=8-5
I already bought a buffing wheel adaptor in anticipation for this build. I just feel like sense I have it I need to use it
