Mountain Man Rendezvous : Hawk and Knife throwing
Cliff Stamp
BANNED
Yesterday on A&E I caught a program on a "Mountain Man Rendezvous", what
caught my eye was the focus which was on tomahawk and knife throwing. There
was a lot more to the event than just the throwing but that was all I was
interested in. It was a well done piece that focused more on the
individuals than the contest, but you did get to see a lot of detailed
information on throwing, both in regards to styles as well as the nature of
the blades used. Some comments :
The tomahawk styles were very consistent, there were minor differences seen
from individual to individual but the base shape was that of the Cold Steel
"Frontier Hawk" :
http://www.onestopknifeshop.com/images/coldsteel/cs-90f.jpg
however I severely doubt that was the exact model they were using.
The knife styles however were all over the place and that really stood out
to me. There were some similar to what Bobby Branton makes, but some that
looked like no throwing knife I had ever seen. Some had drastically upswept
points like skinners, others had huge cleaver like blades with recurves etc.
. Some were that curved that they look like a hawkbill only reversed. Some
of the people that placed very high used such knives.
The throwing styles were fairly uniform. They were throwing from one turn
distance, and you would see fairly fluid motions with clean follow throughs.
The one exception to this was "Running Elk" who threw the knives more like
darts with little to no upper body movement. He placed second overall, which
was even more impressive considering how little he threw. You could throw as
often as you would like, cost you a few dollars a round and your highest
score counted.
One thing I did noticed however was that quite a number of people threw the
knives with edge side up, on many this was to allow a stick with the upswept
point. The targets were very dense and the knives hat to get pretty much a
direct point stick to remain in the wood. In regards to the tomahawks a lot
of people had problems with direct hits and had to adjust their distance to
get a hit on the toe of the edge to obtain a stick.
In regards to skill, they were throwing at a center bull of about 3" in
diameter and the winning score was usually 45-47 (they had several different
catagories). This means that you are hitting the bull 4 out of 5 times and
hitting the next ring (again as wide) on the remaining throw. Consider as
well that this was as friendly a contest as I had ever seen, the mood seemed
to be just as serious as something you would run in your backward, very
little stress, done for a lot of fun.
One last thing that really stood out to me was how loose the head were on
the tomahawks. Several times they popped off even after a correct hit, which
means they were barely on. There was little delay with the person getting
the tomahawk back and throwing again which I infer to mean that they just
gave it a little tap to set it back in place.
-Cliff
Dear Cliff,
Sounds like a very typical hawk & knife competition at Rendezvous. It IS a lot of fun, and though folks are serious about winning they enjoy themselves and usually don't get nasty about the fine points or "umpire calls" that go against them.
It's likely that very few of the hawks were the Cold Steel model. Most throwers at Rendezvous are using forged-head models by an entire universe of individual makers that they buy at the Rendezvous from dealers for $20 to $40. That's the main reason you saw so many heads fly off .... these folks don't spend a lot of time trying to precision fit handles, and they usually are loose as a goose. Most makers build much the same pattern on the Rendezvous throwing heads, so they generally look pretty similar. A few dedicated throwers will spend more for engineering .... the competition throwing hawk I make has won the hawk championship at Riverton 4 years in a row in the hands of different "serious" competitors. Professional-grade hawks like that don't usually come apart in use (I often spend over an hour precision-fitting the handle to the head, and one competitor used a Competition for 2 years before the head finally loosened up and he had to re-set it).
Most of the throwing knives at Rendezvous are home-made from leaf springs, lawnmower blades, and everything else you can imagine. Everybody has their own idea of which blade style is best, and when they find something that works for them they keep making replacements in the same shape.
You were watching a "bullseye" competition. Another common match is card-cutting, where a playing card is pinned horizontally to the hawk block. A "stick" anywhere on the block is worth 1 point, and nicking the card is worth 2 points. If you completely cut the card in half, it's worth 4 points .... which is the reason for the NMLRA 4-inch maximum blade width rule. Obviously, somebody throwing a "hawk" that looks like a broadaxe with an 8 or 10 inch blade has a lot better chance of completely severing the card (if they can toss something that heavy with any degree of accuracy).
More folks should try hawk and knife throwing, and especially Rendezvous. It's a great outdoor pastime and a wonderful way to learn and experience history. Here's a link to the National Muzzle Loading Rifle Association/Living History Foundation web site:
http://www.nmlra.org
TWO HAWKS
http://www.2hawks.net
Yes, there were quite a number of people selling tomahawks and knives there and many of the top finishers used their products. There was also another competition ran a day or so before the main one. I think it was called "The Wilderness Walk". You went out with a group and threw at targets placed in odd positions and you could not walk off the distance, just had to judge. There were also some moving targets, revolving on a large wheel.
-Cliff
Dear Cliff -
The "wilderness walk" competition you described is a very common part of most Rendezvous. They are called by various names, but involve outdoor skills appropriate to the pre-1840 Fur Trade era.
Normally, the competition will include firing muzzle-loading rifles at game-animal and "threat-animal" and/or "hostile-forces" targets at unknown ranges, as well as throwing the hawk and knife at similar targets. Often, skills like making a fire with flint and steel and setting a trap (against the clock) are incorporated. Scoring options are almost infinite, and usually include penalties not only for missing a target but for firing on a "friendly" target or hitting one in the wrong place. These are often applied against a total clock time for completing the course. It is a lot of fun, and does provide a fairly realistic test of your ability to function and survive some of the challenges faced by the backwoodsmen of the early 1800's period.
I have a quick question: was the thrower you named as "Running Elk" in your initial post a very young man with long blond hair usually fixed into a single braid? If so, I know the young gentleman and his family well (ever since the Alaska State Rendezvous in 1991) and he is one of the finest young people I have ever met. He is an expert with tomahawk, knife, and Plains Indian bow. All of the kids in that family are truly outstanding young folks, and are excellent representatives of what happens when people appreciate traditional values and bring the whole family into the Rendezvous experience.
Best regards,
TWO HAWKS
Yes, there was quite a lot more going on as you noted. In regards to "Running Elk", he was an older gentleman for also ran a shop there selling knives and similar products.
-Cliff
Thanks, Cliff. I had hoped that it was my young friend. Since my health went sour I was unable to attend any Rendezvous this summer and missed spending time with that family as I usually do.
Best regards,
TWO HAWKS
