Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I watched a couple episodes of "Mountain Men" recently. They had a young fellow who made his own steel from iron ore he pulled from deep in a cave. The tartara and melt was sort of OK, but I doubt the product was much good, and it took way less time than it does in real life. For the weeks of work and poor amount of product (ignoring quality) he could have got a dozen feet of good steel from Aldo.
This week, they were making blades from a 20"saw blade that looked like shiny chrome steel. When cutting the blade out with a cutting torch, the saw blade was rusty steel. The blank was cut and they told the viewers tat you had to heat the blade to 1500F to make it pliable for forging. He forged it to a rough camp knife shape without even grinding off the torch cut perimeter. Then they pulled out a shallow pan of black goop and said it was quenchant. He heated the blade and quenched and it warped 2" sideways. He said you cam only requench the blade one more time before it is ruined, and did and edge quench, which came out prefect ... according to him. he told how the lower part was very hard and the upper part was soft. You could clearly see a crack going down from the spine at least 1/2 inch. He then struck the hidden tang in a vise and proceed to file away the hardened steel with an old file ( sawing back and forth with the file). He showed how he was filing down past the forge scale and getting the hard steel shine and shaped. You could see what appeared to be grinder marks from a belt grinder on the blade.
Anyway, it just trips my trigger to see stuff that clearly isn't vetted by anyone who knows what they are doing, as well as things to fake the results.
