Mounting bracket
We used to torch and ream to size, but usually not 2" thick.
If you want to try, make a circle burner for your torch, and cut the hole a bit undersized and ream to size.
preheating the plate will be necessary so you get a good pierce, or you could drill a small pilot hole and start the cut from that. I would still preheat the plate though.
Knock the torch scale off and remove the scale in the hole with a burr grinder,then ream. The scale is hard and it is cheaper to use a burr grinder for scale removal than a ream.
Sola Fide
[This message has been edited by mikeS (edited 04-26-2001).]
George, I'm always seeing big end mills, face mills, and counter bores on Ebay .
Take care!! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!
I currently don't have a web site but am working on one.
Buzzards gotta eat, same as worms!!!
George,I don't know how precision you need but you might try a bi-metal hole saw with lots of lubricant.I have done this in 1" thick steel.If you need more precise try a smaller hole saw and a flycutter.Dave
George, if you cen drag it up to Worcester on Monday or Tuesday, I may be able to toss it on a Bridgeport and do it. I'll check with someone later today and see if I can get permission.
--JB
e_utopia@hotmail.com
Hello George,
If it is small enough to practically ship...then send it to me and I'll gladly take care of it. ...By the way, how precise is "precision"? Diameter and location?
+/-.0005, .001, .005 .010"?
Sincerely,
Rob Frink
Beaumont Metal Works
