Mousepad Discovery!
I found my mousepads!
Um, actually, I combined Cliff Stamp's grinding belt on a door method with Buzzbait's strop-sharpening on a mousepad to discover a frankensharpening technique:
1. Glue a sheet of silicon carbide wet/dry paper or stick a sheet of lapping/sharpening film to a mousepad.
2. Lie the blade-to-be-sharpened onto said pad and lightly press its side into the pad.
3. Push the edge forward into the paper or film taking care to not cut through the mousepad (if more of your energy is involved with pushing the side of the blade into the mousepad, this shouldn't be too much of a problem. At least, it wasn't for me) and take care to curve the knife to get the belly-to-point area near the end of the stroke. Continue until a burr is formed.
4. Turn knife over and repeat step 3.
5. Gently alternate sides until burr is removed.
I took the thumbstuds off my 154CM Benchmade Ares and got a hair-popping edge using 15 micron lapping film. I started with 400 grit wet/dry, moved to 15 micron for a bit, spent too much time with .5 micron film and only a sharp point and belly, then return to 15 micron film to put a sharp edge on the entire knife. The thumbstuds are back on and it required little to no skill and less than $10 of materials.
You push the edge forward? I always thought you pulled the edge so it trailed when you strop. At least that's how I've been doing it.
I'm sorry, but I have no idea what you're saying! :confused:
- is the mousepad flat on a table?
- if the blade is flat on the pad, how will the edge touch the paper/film?
- pushing the edge forward ie. like honing on a stone? I thought stropping was edge trailing?
please help - I'm interested but perhaps it's my lack of knowledge here??
Spyken
You can do it edge-leading instead of edge trailing. That's what I did and it was quicker that way.
Spyken,
To get the edge to touch the sharpening film, push the flat of the blade into the mousepad until the edge is more or less flush with the top. And, yes, the mousepad should be on a flat surface. I could have been more clear.
