Josh Feltman said:I feel like a caveman. I need to pick up some adhesive shortly after I master fire. I normally just put the mousepad down on the bar and set the sandpaper directly on top, just sorta holding it in place so I can switch grits when I want. I never seem to have any problems with it sliding around.
Bri in Chi said:I made a thicker base (2 pcs 3/4" MDF glued together) and put a spring-type 1" paper clip on each end by using a wood screw through the hole in the clip. Don't have to mess with glue that way. BTW, I glued another piece of mouse-pad on the bottom to make it non-skid. I used 3M spray adhesive I think.
