- Jun 17, 2006
Once I figured out how to tap the clip mounting holes without snapping off the tap it wasn't that bad.
You can see where the remnant of a tap remains in my original choice for clip placement. I suspect it will always remain there. After I snapped the tap I decided to move it to a new location. I told myself this was an opportunity to make the clip serve double duty as a lock bar stabilizer.
I snapped the same tap off again in the new location!
:thumbdn: Asking in the makers forum gave me good info on how to remove the tap after it snapped off flush (ferric chloride etching solution) and also clued me in on what I was doing wrong. It turns out that you can't use the recommended drill size (#50) for taping 2-56 in titanium. Once I got the broken tap fragment out and drilled the holes with a #48 bit they tapped as smoothly as any hole I've ever done.
It's ugly I know, but at least now my favorite working knife is tip-up like all my others.
