mower
friend of mine bent a mower blade can i
A using heat bend it back
B reheat treat it i have a kiln if so what kind of steel is it likely it was made by honda
C tell him its trashed and see if i can make something out of it i also have a few bandsaw blades if i what to try to forge something together
hope this might help some im not sure how to read the sparks
Blades are pretty soft. You could probably bend it back with a big hammer and no heat, and not have any problems. Hardly worth the trouble though when you look at what they cost. Especially for a push mower, which that appears to be off of.
As far as the spark test, I'd guess that thats medium carbon. Might make a knife, probably a nice tough chopper, although not necessarily that best for edge holding. Thing you have to watch though is thats pretty thin, so you have to be careful you don't decarb it too bad working with it.
The spark test is pretty simple. It takes alot of energy to rip/break a peice out of the steel. So much energy in fact, that the little peice you do break out reaches kindling temperature and burns. If carbon is present, the carbon ignites and cause the little split/fork. The more carbon, the more forks you have. High carbon will throw a really fuzzy spark that splits several times.The spark trail is usually kind of short too, because they keep breaking up and burning. Low carbon will throw a dull spark that stays in one peice and generally travels farther.
The best way to learn how to gauge sparks is to get a couple different hunks of steel that you know the carbon content, and use them for reference. Get a hunk of cheap hot rolled welding grade steel, and a peice of 1095 or O1 and compare the two. If you can find a peice of 1050 or something midway between that would be good too.
Unless you can get it hammered out to the correct shape and balanced properly, running it on the mower will wreck the drive shaft and possibly injure the operator.
Not worth the liability in my world. Tell him to buy another and use that one to practice your knife making skills. They use so many different alloys these days and it's almost impossible to get in touch with actual manfacturer of the blade. That stuff is "shopped out" and not made by the mower mfgr.
Cut it up and test a few chunks to see how it responds to various HT'ng mehtods. Have some fun but don't expect the next Honda mower blade to respond the same way. Some mower blades are great steel some are pure crap.
CRex
