MSC Surface Grinder
Hi,
Does anybody have any experience with the table top surface grinder from MSC?? I have an opportunity to buy one. Any info would be greatly appreciated.
Take care,
Richard
I have one....its not MSC...but they are all made in taiwan by the same factory.....works great...HOWEVER....you MUST add some sort of caliper measuring device on the downfeed cause the dial that there doenst tell you the truth.....it works great....you also NEED a mist coolant device or you will burn your steel and make it curl. Trust me, I know.
I should add you need to get a magnetic chuck too if you are going to use it the way it should be used....your only alternative is to clamp steel to some sort of plate.
