Okay so this might be a dumb question but I’m trying to figure out how to clamp some handle material with a 30ish degree angle joint for the material. Is there a really simple solution to this that I’m over complicating it?
Going to set a couple mdf blocks up to hold them in place flush and grabbed some CA glue and activator. Its just to put 1/4" G10, and match up some stabilized wood with a simple angle joint. I'm also adding a liner in the same colour as the block. Full tang so hoping I'm careful enough to cut them both close enough that I can grind down any differences. Will put up picks this weekend when I hopefully have them glued up.
Thanks everyone for the responses.
