greetings, and welcome. Since you are here,I'm guessing it's a Buck multitool. If so you can send it in to Buck at BKI,1900 Weld Blvd. El Cajon, Ca, 92020. send a note describing the problem and advising if the tool has sentimental value. If the tool is warranty damage they will fix it or replace it( if not sentimental). if the damage is not warranty covered, instruct in your note to call you with a cost Before they send it back to you.
hope this helps, Buck has excellent service. This should help until Joe, Jeff, or another more experinced member gets online. Dont forget the Buck Collectors Club.
guy
