If I remember right, 1095 has a lot narrower window than 1084 for the quench, meaning as soon as you get it to temp, quench. 1084 gives you a couple seconds to" get to" the quench.
Just a quess, but looks like when you went tip first then rocked it the tip came out of the quench? If so part of the tip probably fell below the harding temp causing the double temper line there. Just my guess. I played around with the tip first, wait, rest of the edge, then back to the tip and so forth quench, but for most I now just quench tip first and hold till it stops glowing, harding a bit more than half the blade, with the harding line highest at the front and narrowest at the ricasso.
