Muskrat Morph
AFAustin
I’m not the first one to modify a Muskrat so as to have a wharncliffe blade accompany the clip, and in fact my inspiration for jumping in was jmarston’s very nice job on his Case model: https://www.bladeforums.com/threads/case-improved-muskrat.1599529/#post-18269154
(jmarston's nice mod)
I really think clip + wharnie (or sheepsfoot) is a terrific blade combination, and I had a great candidate for the mod: my Case Muskrat in orange curly zebra wood. It’s a beautiful knife, and doesn’t even suffer from the sometimes Case Muskrat malady of a proud spring. See, e.g.: https://www.bladeforums.com/threads/lets-talk-muskrats.1374363/ (posts #42 & #52).
But my mod skills are modest, and while I’ve managed a few nice tweaks with my trusty Work Sharp Ken Onion and Blade Grinding Attachment, I’ve never tried to cut off a large section of blade. I use a Dremel for various chores but have never used the cut-off wheels at all, much less on a very special knife. But I finally decided that today was the day.
I first sharpened up both clip blades, and then made the decision as to which clip would undergo surgery. The logical choice, I guess, would be to leave the mark side clip intact as the master. But there were two issues that caused me to be unorthodox and do it the other way around. First, the mark side clip when open sat at a downward angle which I thought more appropriate for a draw cut wharnie blade. And second, the mark side blade’s point sat a little proud above the well when closed, and while I could’ve brought it down a little, I really didn’t want to change its shape, not to mention the extra work it would’ve required. In contrast, the pile side clip opened pretty straight out with no downward cant, and when closed the tip sat comfortably deep in the well. So, I was happy to go the unorthodox route.
I secured the knife in a small vise, and fired up the Dremel. The little cut off wheel, as flimsy as it looked, did its job admirably, and in a minute or so the amputation was done. Now it was time to shape the wharnie, and I went to the WSKO BGA. A while back, Gary Graley showed how to fashion a little insert between the belt and the platen on the BGA: https://www.bladeforums.com/threads...ife-grinder-attachment.1445402/#post-16644875 I used the platen and insert and began a belt progression to shape and smooth out the wharnie. I liked jmarston’s version where he kept the hump---a nice tribute to the blade’s origin---but decided I was going to make mine rounder and with more of a typical wharnie shape.
I’m pretty pleased with how it came out. Actually, more like relieved that I didn’t screw up such a beautiful knife! It may need a little more tweaking here and there, but it’s pretty much done so I decided to go ahead and put up this thread. So, here it is: my Hawbaker, or Improved Muskrat, or maybe just Morphed Muskrat.
Thanks for looking,
Andrew
Hey great job! Mine has been with me ever since I modded it. A constant companion in the woods, the shop, the city and the home.
Glad you took the plunge! Pretty much every knife I regularly carry gets modified. Once you are confident in your skills, pretty much every factory knife can be modified to better suit your needs.
That turned out really great, nice work:thumbsup: It looks like it came from the factory like that.
They should all be that way. A knife with two identical blades never appealed to me.
Thank you, gents. I really appreciate all the nice comments and likes.
jmarston, thanks for your post---your muskrat mod was indeed my inspiration and motivation. Interesting that we ended up with two different versions of a wharnie. Mine came out with a very acute point, which can be handy, but I also really like the sturdy look of yours. Did you do it all on belts? If another muskrat comes my way any time soon, I may try to duplicate yours!
Andrew
Andrew
I really love the look of a nicely shaped sheepsfoot. I was going for the longest cutting edge possible while being as sheepsfooty as I felt I could. The tip of mine often gets used for cuticle trimming and nail gunk cleaning. And opening boxes. And trimming threads. And...
I would encourage you to keep modding. Some of my longest carries are knives I have modded. I reground a Buck 301. I was not happy with the thickness behind the edge and how th shoulders of the hollow grind felt. Cuts much better now. Easy open notches are another good starting place. While I used to enjoy getting a brand spanking new knife in the mail, nowadays my joys come from finding old, tarnished, rusted, gritty blades and restoring them to their former glory. A knife with a chipped edge or broken tip is almost never more than a 5 bill. With a little patience, they almost always come out as perfectly serviceable knives I throw in a truck, give away to a hopeful knife nut or stash around the house. And if I can't fix it, and there has only been one or two, well these days a burger at the local diner runs around 15 dollars so I am not out too much. I am a knife modding fool and encourage others to jump in too.
