Thanks for the info,Ikie-very scientific-looking back,I guess that I should've done a test peice first.If you try the mustard and FeCl please post pics of that also.
Thanks Mike,and thanks for the inspiration:thumbup:
Ask and you shall receive. I did do the FeCl etching test on my test piece. I also did another layer of mustard on the right end of the test piece. Here is what you're looking at.
Sections are 1 through 6 from left to right in the photos. Rows are explained from Bottom to top.
- IMG 1271,,,The first application of mustard to all six sections.
- IMG 1275,,.The fifth application of mustard. Section 1 had one appliction, section 2 had 2 applications, section 3 had 3, section 4 had 4, and sections five and six have the fifth applicaiton on them in this photo.
- IMG 1293 is a close up of section 4. You can see parts of 3 and 5 to either side.
- IMG 1295...This is a photo of the entire test piece. Sections 1 has one application still, 2 had 2, 3 had 3, 4 had 4, 5 had 5, and 6 had 6. From bottom to top the treatment for each section was: Bottom row is with no FeCl etch and no bluing. Second row up is with 3 minute FeCl etch. Third row up is with 30 seconds of bluing. Fourth row up is with a 3 minute bluing after the original 30 second bluing.
- IMG 1303...Closeup of Sections 5 and 6 after all mustard applications, etching and bluing.
Some things that surpised me:
The 30 second bluing was actually darker than the bluing that was applied a second time. I don't know what to think about that. The 30 second bluing isn't very consistent or uniform though, as compared to the top row that received the longer second bluing.
The etch in the second row up from the bottom is very nice. I really like it!
A fifth application of mustard looks about the same after bluing or etching than only four applications. However, without bluing or etching the fifth application makes a difference.
A sixth application of mustard didn't make a whole lot of difference in the appearance.
I took these to 800 grit I think, but didn't spend a lot of time making sure I got all of the scratches out like I would on a knife. This process really shows scratch marks, so it's imperative that all scratches be polished out!
My decisions based on this experiment will be to usually apply mustard six times. The first five will be random dots of mustard. The sixth application will be a thin layer over the entire knife. I will follow most of them up with 3+ minute FeCl etch. I'm working on a 52100 hunting knife right now, that my customer wants a mustard finish on. Since I'm going to be edge quenching the blade, it will be interested to see if the hardening line shows up through the mustard patina when I etch it. I'm thinking that it probably will. Ok, I'm hoping that it will.
Any thoughts or comments on my experiment or any ideas how to improve it would be greatly appreciated.
Ickie
