Cliff Stamp
BANNED
- Oct 5, 1998
I bought this knife awhile ago because of Carter's reputation for high cutting ability. This has a 9.5" blade, 0.190" thick, laminate steel, weighs 410 g. High flat (or very shallow convex grind), 0.8" wide on a 1.6" wide blade, very small secondary edge bevel, 0.010" thick behind the edge.
Initial sharpness was above average, 120-140 g on thread, but well below the blazing sharpness you can get from Spyderco and others. It would shave but not smoothly and required a little draw. The cutting ability was above average, 25-27 lbs on 3/8" hemp on a push, no aggression on a draw, 5-7 cuts to point one inch basswood dowel.
This was a decent level of cutting ability, about 25% higher than the Camp Tramp for example, but not quite as high as I expected, the performance however was a little less than optimal on the hemp and such due to the less than maximum sharpness. The wood carving ability was also hampered by the low primary grind.
The tip has a very long distal taper and thus the penetration is very high, on a stab it readily sank right though a standard phonebook and penetrated significantly into the next one, 920 +/- 10 pages.
The blade however really came into its own when it was used to cut thick woods, the handle was very comfortable and it sank smoothly into the pine, matching the performance of Kirk's bowie I used a few years back. It had a similar feel of a smooth cut into the wood, rather than an abrupt cut.
It matched the performance of the Kellam axe in regards to number of swings, but it was a world apart in regards to feel. However the edge turned on the first knot, the axe and Billhook plowed through much harder woods with no problems.
Overall the knife was very solid through a lot of utility work, really excelled on thick wood cutting, but could not handle even knots in Pine and would get mauled on limbing or trying to cut harder woods. Not quite sure what to do with this one yet. I will sharpen it up and repeat some of the stock work in any case.
This was sold as a "Camp Knife" but Carter noted that it was designed as a Hog hunting knife. Pictures should be up in a few days. Very nice solid leather sheath.
-Cliff
-Cliff
