well actually 1.5 oz
borrowed on several other folks ideas and came up w/ a very light, small grill that packs away in one piece
it consists of two aluminum tubes and eight titanium bike spokes
the outer tube is a 12" section of a Easton aluminum arrow, the inner tube is a 5/16" thin walled aluminum (can be had at Ace Hardware)- the eight ti spokes fit in the inner tube, the inner tube into the out tube- two small plastic caps (you need to cut the 5/16" piece slightly shorter to accommodate the caps)
drill holes for the spokes
you could do this on the rear cheap by using two sections of an arrow, use steel spokes instead of ti- just divy the spokes between the two arrow sections and use a small rubberband to keep them together
the grill will be used mainly for grilling small trout, I haven't tried it yet- but think it will handle my .7 l pot as well in a pinch (out of fuel)- I don't think it would handle anything much over that
if you needed something heavier, simply up the diameter of the rod (ti or steel)
