- Nov 1, 2011
So recently I broke my paddle strop, (it was a small compact strop from a man who makes strops
, It was a good strop, and the build quality had nothing to do with why it broke, I had it hanging up and was moving boxes and it fell off the hook and I stepped on it , which I'm sure cracked the wood. None the less it snapped . So a fellow forum member sent me a barbers type strop that they had and it works great and I love it, but I've been hearing a lot about Balsa wood so I decided to try it, here is what I did.
First I hit my local hobby store and found some "Balsa wood kits" that have about 12-13 pieces of balsa in them and my intentions were to get that, and mount some of the smaller pieces on edge pro blanks and mount the bigger pieces on some scrap wood. Well as I'm getting what all I was gonna need and the total was getting pretty expensive, I had the balsa kit, glue, some pieces of hardwood to mount the balsa strips on, and I think the total was getting to be around 30 dollars give or take, But I had enough stuff to make about 4-5 edge pro strops and 4 hand strops.
So I'm about to checkout and I'm thinking for 30 bucks, I could get (insert strop here) online forgot this, So I go put all the stuff back, Well I run into an employee who is talking about how she makes straight razors
, so I approach her and I ask her how she likes balsa , and she praises it and proceeds to tell me I'm kinda crazy for buying all the stuff I was about to, and directs me to a square piece of Balsa wood that is 4 inches wide , and about 12 inches long & it has 4 sides, BINGO, I examine the wood , It's flat , no dings or anything, and she says pull up our website on your phone and you will get 40% off of this item so I got this nice chunk of balsa for $5.00 bucks, I get it home and load each side with a different compound, Black, white, and green and left one side unloaded.
I'm not gonna lie I had serious doubts about using this stuff, but I trust this forum so I grabbed my zdp-189 endura and off I go , First with black, Then with white, then with green ,and finished with the plain and I'm still having my doubts so I grab some newspaper and It slices it like butter! Still having my doubts I grab my benchmade 810 that was a little dull, and do the same thing and same results. So any of you guys on a budget or just refuse to fork over the kind of money some strops go for , Grab yourself a block of balsa, then hit up your hardware store and for $2.98 a stick you can buy compounds, I already had the compounds so I was GTG with just getting the wood. The best part about this chunk of balsa is unlike leather if your new to stropping your probably going to cut your leather , hell I do it still and I've been stropping for a while now, but if you cut your balsa or it gets loaded up or what have you, all you need is some 100 grit sandpaper to sand away the old compound or your knick out if you cut it and there you go , a brand new stropping surface. Examine your wood also before you do anything with it and make sure it is flat , or doesn't have any imperfections , If it does you need to sand it before you do any stropping, I guess I got lucky though the piece I got didn't need anything but some compounds. Overall $5.00 well spent!
