My backpacking/camping survival kit
I have assembled a small survival kit I would like to share with you guys. My intention was to assemble a small and lightweight kit to accompany me on backpacking trips. It is to compliment the things that I already have with me (generally a tent, sleeping bag, knife/multi-tool, food) and serve as a backup in case of emergencies. If I wander away from my camp and leave my backpack and main gear, I will make sure to bring this with me.
The first goal I intended to achieve with the kit was to get items that would allow me to reliably start a fire. Since I generally don't carry firestarting items in my backpacking setups (except for a small Bic lighter for my stove), I can also use the kit to start the spur of the moment camp fire.
Second goal is to give me good options in the event that I become lost.
It also provides both back-up water purification and storage, however since I always bring a water container and purification method (filter or drops) it is not a huge consideration.
Onto the contents:
Fire
Full-Size bic lighter. I might down-size to a mini-bic, but I find the full-size gives a lot more lights.
Stormproof matches. You could get by with normal waterproof matches stored in another water-tight container, but these matches are the best I have found. They burn hot, and strong. That container there has 25 matches stored in an air and water tight container. It is a bit bulky, but I feel they are worth it.
Wetfire tinder. There might be better tinders on the market, but wetfire burns very well. I have two pieces there. It's my go-to when I can't gather dry tinder in damp conditions.
Tinderquick and Trick birthday candles. Tinderquick isn't as good a tinder as wetfire in my experience, but it has a very good weight/size to performance ratio. It repels water, so it works well in a damp environment.
A few trick birthday candles are good to have handy when you need to need to set a small item ablaze. They burn slower than matches, so the chances of you burning yourself are smaller.
Firesteel and Striker. Probably pretty obvious. I can (potentially) start way more fires with a firesteel than I can with matches/lighter. This is my go-to method when I have dry tinder and time to spend getting a fire going.
Water
Aquamira chlorine dioxide tablets. These will serve as a back-up for if my main purification method fails. I have 6 of these in the kit. If you use these, before you throw away the packaging they come in, look at the bottom of it for the expiration date, then write it down on the individual packets of tablets. They are good for about three years, so make sure you swap em' out as time goes by.
Water storage bag. That is a small and light water storage sack. It has a line marked on it for 1 quart, which is good since that is the amount compatible with each of the purification tablets. (available here http://www.bepreparedtosurvive.com/WaterContainers.htm)
Navigation and Signal
Button Compass. I believe this one was made by Tru-Spec. This isn't the best one on the market. I would suggest that you cross-check this compass with a higher quality one before you set out on an expedition. Also, if you are using this in a survival situation, cross-check this compass with the sun/moon whenever you can. Another good thing about having a second compass, is that you can cross-check your main compass just to give you peace of mind. For the weight though, this compass earns a spot.
Fox 40 Micro. Very loud, and it is flat and thin, unlike the normal Fox 40 whistles. I don't keep a whistle anywhere else in my setup, so this item is a must in my survival kit.
Signal Mirror. This is the smaller sized one. 2x3" I believe. You could get by with just a small piece of a scrap mirror, but this one has the sighting hole and instructions for use. You can also use this to shave in the field or check your face for scratches/ticks/whatever.
Misc.
The small green item is 2 scalpel blades wrapped in 100mph tape. Weighs pretty much nothing, and can serve as a last ditch cutting tool.
Trash bag. Somewhat bulky, but has a lot of different uses, such as: Capturing water, using as an improvised sleeping bag, making a shelter, or poking your head through for that rainstorm that catches you off-guard when you are away from your rain gear.
The kit is stored in a 6.75x6" Aloksak. The sack itself could be used to store water. It has room for a few more smaller items if I wanted to expand. I don't know the exact weight, but it fits easily and comfortably in a cargo pocket.
Here's a pic of the contents laid out
All packed up.
Other considerations:
No, there is no cordage in the kit. I always take 550 cord with me when I go out, so I won't include any in the kit.
No duct tape either. I keep duct tape both in my first aid kit, and my repair kit (which I think I'll post here later).
You might consider putting a really small key-chain type flashlight, such as the excellent photon micro-light in the kit, but I left it out. I may add one later.
I keep my spare batteries more handy, but this would be a good place to store your spare batteries for your flashlight/GPS.
Might be a good place for you bushcrafters to store your knife sharpeners. If I was going to add one it would be the Fallkniven DC3.
Waterproof paper and pencil might be a good addition, but I didn't add it. Paper could come in handy for leaving notes, or making maps.
Might considering writing up some survival instructions on a note card and laminating it. I have a decent amount of survival knowledge/training, but when you are in a panicked state of mind, it is easy to forget the basics.
Well that's it guys. Hope this was beneficial to some of you. Comments and suggestions are always welcome!
Stay safe, have fun! :thumbup:
Jeremy
You've got a great looking survival kit there. Not fully knowing what you carry with your other gear it's tough to say what you might need or want to add. Though sometimes certain items you should have in both should you lose or become seperated from your main pack. I put a really in depth survival kit together and posted it on the ESEE forum last winter. I'll post up the pics and maybe you'll see something that you'll think you should have. If you want to see the thread with a full list of contents, it's on the ESEE Forum page 121 ( My EDC Survival Kit ). Other than that I would really think of adding a small fishing kit with spectra braid line, 50-70ft. Nice work!
^^^ Nice kit!
I needed something as light as possible.
I carry a FAK that I feel gives me a lot of possibilities as well, and for certain longer trips, a repair kit for my gear.
Nice kit dude, that "Wetfire" tinder is awesome. One of these days I'll get around posting my own PSK. Fits in a maxpedition thermite.
Thanks for sharing.
Some things that came to mind looking at your pictures.
I would put a zip tie around the top of that Bic lighter. To ensure you have gas in it if/when you go to use it.(Insurance)
I would take the waterproof matches out of the case and free up more room in your kit. I would simply put them in a small resealable bag.
I would also include some braided fishing line on a bobbin for a sewing machine, include a few sewing needles small fish hooks and you have a multi use item. Cordage,repairs, fishing.
I would also add just a few large bandaids and a tube of bacitracin. sp? I understand you carry a FAK but this is your last ditch kit so it wouldn't hurt.
Just some food for thought.
You have fire, shelter and signaling covered and IMO that's all you need in a compact kit. I use Aloksaks for a basic kit and one for my first aid as well, they are great.
Does that orange whistle have a clip on it? Is it loud? I've got a Storm but I found one that looks like yours with a clip for $.99 and debating getting a few, but only if they're relatively loud.
Thanks for the tip regarding the matches/lighter.
With respect to the items you suggested, let's remember, we are talking about keeping myself alive for a short period of time until I can self-rescue, or until help comes. I can go without food for a few days, so I don't really need to be able to catch fish. I can also go with damaged gear for a few days as well, preparing a piece of gear isn't really going to save my life. Also, I am not going to die from a wound that band-aid is going to treat. If you are going to bleed out, it is going to be from arterial bleeding, and a band-aid isn't going to do much to a severed femoral. Yeah, the small wound could go septic, but I don't really care to take the "what-ifs" that far. My primary concern is keeping myself hydrated, and keeping my body's core temperature where it needs to be. If I die during a backpacking trip, it's probably going to be from dehydration or hypothermia, barring an unfortunate accident/bear encounter. My second concern is either a) getting back to the backpack full of gear, or getting to an otherwise safe location, or b) hunkering down and waiting until help arrives, and making myself more visible/audible while doing so.
The problem with these kits is that it really easy to say "well maybe I'll just add this", and then "well one of these wouldn't hurt", and before you know it, you have a kit that weighs twice as much as you were setting out for. I don't know about you, but when I already have a 50lb pack, I don't care to add 5 more pounds of survival gear.
