- Jul 11, 2003
Hi buddies!
I've been working on a blade grinding jig that would encompass both fixed and folding blades. The main problem I was experiencing was how to design a jig that would be effective, yet flexible. After several prototypes, I think I'm close to getting what I want. The following pic is the basic jig. Its made from a chunk of 2" angle iron. It features a big knurled knob and a knurled nut for setting the depth. A series of threaded holes provides many choices to hold the blade in position.
This is a view of the business side. Note the threaded holes - they are all 6-32.
Side view. The brass fixture you see is for holding fixed-blades.
Bottom view. The small white thing at the bottom is actually a Delrin swivel on the end of the knurled bolt. Note the corner of the angle iron has been smoothed.
This is a better view of the knurled bolt and jam-nut setup. The tall nut is called a coupling nut. Please don't laugh at my weld. I had to grind it smooth because it was so ugly - I was running out of argon when I welded this!
This one shows a fixed blade installed and ready to rock.
This is a view with the jig tilted a few degrees. You can see that its possible to dial-in a nice even grind on both sides of the blade!
In this pic, my pencil is pointing to the eccentric. This is merely a thin piece of a 3/8" rod drilled off-center. The eccentric helps to put the blade into exact position to keep the bevel precise.
Last but not least, here is a view of the keeper for the tang end of a fixed blade. It's milled to provide a snug fit for a 1/8" thickness, and the top screw is to take up any slop.
I had the angle iron kicking around the shop, but the hardware was ordered from McMaster-Carr. If anyone needs a parts list, I can probably find the old invoice and list the part numbers here.
Thanks for looking!
Thanks for looking!
