- Oct 23, 2011
I spent about 50 bucks at my local knife shop on a Buck Spitfire because the silver aluminum with orange accents really caught my eye.
Unfortunately the shop was trying to close up for the night so I didn't get a chance to really play with the knife before buying it... First mistake...
My Buck Spitfire is just sloppy... Plain and simple. The lock shifts around and chambers... The retention is so poor that I can literally shake this thing open.
The pivot is completely loose and spins freely... I can spin the bolt on the pivot with my finger and I can feel that it isn't threaded or connected with the other side.
The blade play in this knife is... Kinda unforgivable for a lockback. The blade wobbles back and forth and up and down fairly noticeably. When the Spitfire is close up, it can clammer against the sides of the scales. Centering is also really bad.
The spacer is not level with the scales... It looks pushed in... So the spine of the knife handle is not flush or even. I also notice that the lockback button thingy extends a little beyond the scales and I can actually see under the lock bar.
And to put the nail in the coffin... The grind on this blade is just plain sloppy. There are visible burrs and slight unevenness all up and down... Almost as if someone was drinking at the grinder when they did this knife or something.
Did I just get a dud or is this the legendary "Buck quality" I keep hearing about. Seriously... I have Cold steel folders from Taiwan that have better grinds and lock up tighter than this Spitfire.
I'm just really disappointed. I don't even know if it's worth calling Buck about because all these things seem to be just how the knife was made and not manufacturer defects.
