My Carrier For CR 123's
Ever since I got my E2e, I have been obsessing about finding a carrier for an extra couple of CR 123's. Maybe it's part of the syndrome that makes one gadget lead to another? OK, so maybe I should get out more......anyway: I just made one and wanted to share this.
First off, I was looking for some tubing that would be the right diameter for holding these batteries. Not so easy to find: everything I tried was much too large, or if it was the right inside diameter, it was too thick walled to be practical. I even got to carrying a used CR123 in my pocket just to check on anything I came across - like I said, this was becoming an obsession!
So, while walking past a neighbor's trash can one day, I noticed one of those "mechanical" mops. I got out my handy battery & found that the metal handle of was exactly the ideal diameter - just a fraction larger then the batteries. So I grabbed the mop, took it home and cut a section of the handle. Then I carved a wooden plug for one end, sealed it over with some epoxy and used the rubber tip that came with the mop as a removable cap. Result is exactly what I was looking for: a nice looking aluminum case that is moisture proof, only a tiny bit bigger than the batteries and smooth all around so it carries comfortably in my pocket. And, best of all: zero cost!
Now, if I can only find a Cordura case that'll hold the battery case, the E2e and my favorite folder..........
Some people just use another flashlight as a holder. The Inova X5T would be a good, waterproof holder.
I check my 123 voltages and when they go below 2.95 or so, I carry two 123's taped together (side by side). I tape the ends too so I won't get an accidental short. It's a compact package and I just throw it into a pocket just in case I have to switch out the batteries.
some metal or plastic (or glass too) cigar cases are about the right size, also. the ones w/a single cigar in them.
greg
Yeah, those aluminum cigar tubes work great. Plus, you get to smoke the cigar first.
I posted a reply about a 123A carrier in the Tactics and Training section under Wilderness and Survival or something like that. It's under "Carrier for cr123A?" I think. That is, if anyone is interested. Not a long reply, I'm just to lazy to type it again:D . Sorry, guys.
-DC2
I use the surefire spares carrier. Holds six batteries and a spare lamp.
i have the BHI surefire accessories pouch
elastic tubing for 6 batteries with room for spare bulbs
but it comes with BTS that needs a BHI web belt to really hold on to
