Using waterstones, I'm not satisfied with my edges. I can take a simple carbon steel through a full range - Cerax 1k (get a big burr on both sides), Suheiro Rika 5k (faint burr), Kitayama 8k (I don't feel a burr here). Under a loupe the edge looks good. I'm definitely hitting the apex. Sharpie trick shows I've removed all the marker. I draw the edge over the inside of the kitchen cabinet to supposedly remove any burr.
But the edge is meh. Might shave reluctantly. Might not.
Then I can strop, maybe five to 10 passes on each side, and the edges is screaming sharp. Shaves with no resistance. I doesn't matter if I use generic green compound on leather or Shwartz CBN .5 micron on balsa, I get the same results. (Though spending more time with the CBN does improve it even more. I've whittled hair at times.)
I don't think the stropping its self is removing enough metal to explain the improvement. Maybe something to do with the wire edge? I know I shouldn't be moving from the 1k until the edge is better. So I want to do it the proper way.
Thoughts on what I'm doing wrong?
Thank you
Thank you
