My first attempt at a "copper wash"
I've been carrying this Kershaw/Emerson CQC-4kXL as a beater for a couple months, but felt it could use some personalization.
I First dissasembled, and set the blade to sit in some toilet bowl cleaner cut with hydrogen peroxide for ten minutes. I removed the blade and allowed some pennies to dissolve in the solution for a half hour. I set the blade in the acid/peroxide/copper solution for an additional 15 minutes.
I noted that the copper from the pennies had begun to implant itself onto the steel blade.
I set up an empty Sriratcha jar filled with cat litter, seven small rocks and about 20 pennies and set the blade in there. I then proceeded to wrap it all in a towel and tape, and placed it in my clothes dryer, set to 'fluff'
20 mins of tumbling and reassembly later:
Just wonder if anyone else has tried something like this? I devised this plan after dissolving copper wire in ferric chloride and dunking blades in the solution, to give a precipitous copper finish. This method is by far more relaible.
Just spent a few minutes scrubbing the finish with the green side of a sponge, no change noted. The copper is in there. Science is weird.
thought pennies had almost zero copper nowadays mostly zinc? guess enough for that go figure......
new pennies are 2.5% copper - pre 82 pennies are about 95% copper - even with new pennies, its probably cheaper with pennies if you had to buy new
i like the outcome - thanks for sharing
Looks awesome, nice work. I love the steampunk vibe the finish gives, I'll have to try this. Thanks for sharing.
Does anyone know what steels will work/accept a copper wash coating and which won't? My understanding is 154cm won't take the process well.... does anyone have any experience with CPM20CV?
