The man I made it for showed me a picture of a Western Bowie and a picture of a coffin bowie and said he wanted something similar to the two. I used my western bowie as a very rough idea for the blade. The handle is not quite a coffin bowe handle, but I thought it was a good mixture. The handle did come out a bit shorter than I wanted.
This blade is much narrower and about 1" shorter than the western. The blade is .25" thick with a full flat grind.
My origional intent was not to have a butt cap but as I was sanding I ran into the holes that I drilled for the tang so I had to shave some wood off and put two pins and a butt cap on it. The cap is milled on the inside so the end of the tang goes into the cap about 3/16, just enough to put the pins on.
The guard was secured using JB weld. I tried to silver solder it several times but ended up with JB. I liked the JB Weld so much, I think I'll use it as often as I can.
