- Aug 29, 2014
AFter finishing up my sword and scabbard, I decided to try my hand in a full DIY knife making process. SInce I lost my mora, and deciding not to buy another... I said to myself lets try to make a bush knife. I'm into fishing, and often end up trying to cut down trees and branches in order to retrieve a snagged lure or just to get to a nice spot. Quick surfing led me to my first pattern wich I found will work nice for chopping.
I got some old spring steel which was straightened using a makeshift propane oven
not having an anvil, I used a big vice as one...
I've cut out the rough shape using an angle grinder..
I made a forge from an old boiler, and hammered out the bevel. the steel is roughly 4mm thick, so i flattened the bevel to about 2,5mm.
using an improvised belt sander... i got the rust out...
I've gone through all the heat processes, and polished the blade up to 2500 grit
made some micarta using two T-shirts, and made the handle
I had some old leather, that was rigid, but damaged, so I glued a thin strip od fine leather on it, to make a simple sheath, which i plan to wet/and shape later.
and here it is... my firstborn. far from perfect art some of you post here, but for a first timer.. came out pretty nice.....
This was made using only basic tools, a hammer, belt sander, a stand drill and a lot of sandpaper and elbow grease. Comes toshow, that you can make something from nothing, if you're up to it.
